The fix for my endless alternator failure's
I'm kindof leary about ordering the ad244 alt. since I had 2 delivered locally and they where both 105 amp. alt.s
would you happen to have the phone# of LKQ?
Thanks
http://www.lkqcorp.com/
Order a KG3 alt from a late model truck, all the information to get the right alternator is in the first post of this thread.
If anything you will now get the voltage you were supposed to be getting to the pump since the alternator will charge properly, if you have low voltage now then the pump has been underpowered.
It will be perfectly fine.
One last thing, the pump PULLS the amperage it needs, this is different than voltage. The amperage is there for the usage but the pump will dictate how many amps it pulls from what is available. Now on the voltage, if you supply it with more voltage it does work the pump harder, so if you now have low voltage you are underworking it. The voltage would be more of a concern, but again the voltage is regulated on the alternator and the pump is built to operate in the regulated range.
during the day the charging sys. is below 13V I estimate 12V going by the OEM guage (thats w/ radio, AC Bi level vent not AC turned on).
last night I was cruising down the expressway as usale 12V then I turn on my headlight atl. was then charging at well above 13V I estimate 14V then I turn on the AC and it stayed at 14V even parked at idel I had 14V (it stayed at 14V w/ high beams on also.
so why doe's the atl, charge normal w/ headlights turned on doe's this sound normal?
Thanks
Thanks
Your problems above sound like alternator or maybe even ground issue's. Check all your ground wires, take the battery connections off the battery and clean them really well, CALL LKQ like I said and order the right alternator, get a connector for the alternator from NAPA or Oreilly and install that. Everything you need to do this right is posted in this thread. If you still have problems after you do all the above things take it to a shop. There is only so much that can be diagnosed over the internet and your problems are beyond that. And stop asking for a AD244, nobody at a parts house or junkyard knows what that is. It has been posted so many times to get a KG3 option alternator.
Here is the information for the connector
AC Delco part PN# PT1136
I got mine from NAPA so you can try going back there or go to orielly
http://www.oreillyauto.com/site/c/se...aro&vi=1361450
And I believe sjsingle1 now has a spare, PM him and see if he want's to get rid of it or not.
did the new connector from NAPA have the same color wires? and a decent weather profh cover?
looks like the alt. needs to be removed in order to unplug this connector is this true?
I crawled under the car and connected the 3rd big 3 wire to alt. and ran it up to the + of battery will connect to + battery this week.
Thanks
Thanks
my OME charging problem dissappears when outside air temps. are less than 80degrees so looks like I'm good till next hot summer.
