After 3 alternators and recently seeing this thread, I ordered the parts last night. Hope it comes in soon and works as well as said. I effin miss my car!
You will not be disappointed. Very simple swap and makes a hell of a difference. You'll love it!
I put my truck alt in and my gauge seemed fine but the other day it was shaking again, I had bought the wire Above but didn't swap that , would that cause the truck alt to react that way? Maybe the batt? Or the alt it's self ?
Originally Posted by camaroboy14
Also , I am planning on getting the batt tested(old optima batt)
And I am planning on swapping the wire out , if both those show/do nothing I will be looking for another truck alt .. Prolly a new one, so my question is can I buy this truck alt at autozone? If so what can I type in to look it up? Thanks for the advice
Figures, an alternator I ship to damned Germany would be the one that acts up....
Install the new wire otherwise we are all just guessing. If that doesn't fix it send me back that alternator and I will have it warrantied for you.
K,I tried searching no luck, any part numbers ??
If you go to an auto parts store get an alternator for a 2003 chevy truck 5.3 engine 145 amp alternator.
Originally Posted by sjsingle1
i taught him well !
Yep!
Originally Posted by ranman02ta
I completed the kg3 alt install saturday, it 100% stoped the lught flicker, it was a easy direct bolt in. cost 81$ for the alt, with 1 year warranty and 13$ for the wire. Very worth wile.
thanks
Originally Posted by HibachiZ28
Just an update, installed mine around 8,000 miles ago. Still working like a charm! Taking it to the track this Friday for the real test.
Good to hear guys!
Originally Posted by youcancallme29
Well stocker finally quit on me. Going to upgrade to the kg3 145. My questions to you guys are. Is the replacement of the pigtail (4pin) necessary or only on the cars where the harness is to short? The big 3 wire upgrade where can I get it? or is it better to just do it myself ( getting the wire and the end links. If so how much wire do I need and do I run them inline with the existing wires or just in place of? Thanks guys I know these question have been asked a million times, just love my car and want to get it done right the first time.
P.S. Thanks again.
It's not absolutely necessary to replace the exciter wire it's just incredibly dumb not too. They fail and cause problems, it's right there in the area so just do it at the same time. Plus it's a bit of a stretch for the stocker. As far as the big 3, I still haven't upgraded any of that wiring on mine. You can if you want. Sorry, I can't answer where to get the wiring or how much. Get a ruler and measure the existing wire and then measure where you would run the others then buy and extra couple feet.
Originally Posted by JVJLS1
Swapped mine today and finally that dang gauge's needle stopped shaking around and my lights stopped flickering. THANK YOU SOOOOOOOOOOO MUCH!
Sweet!
Originally Posted by Big Black SS
went to the salvage yard today bought a alternator ($65 1 year warranty) off a 2003 silverado 145amp kg3 installed it ,bought the pigtail from oreilly pt1136 installed it, and NO MORE lights flickering and no more voltage drops. took it for a drive had the AC blasting the bright lights on and the 1000 watt amp system bumping full blast ,nice and steady at 13v. even turned on the blinker to see if the volt needle would pulse and it didint . just want to thank the O.P 00pooterSS for helping me through this thread and P.M's
No problem holmes.
no need to thank me
Thanks :p
Originally Posted by 1BADAIR
will the newer 145 kg3's fit?
everyplace around here has 07-11's
Like SJ said, newer ones have 2 pin connectors and will NOT work. If you can find a 4 pin it will.
ok, I just installed my 03 Truck alternator and the dash indicator is reading below 13. i took it to Autzone to test; shows my Alt. failed!... ARG!!! ok so now what? and a quick question... I want to make sure I didn't mess up the excitor wire (would that cause a fail?). How many wires are connected to the excitor wire plug???
All looks well.... I purchased a reman. from NAPA(Delphi)...The instructions say I have to open the alternator and do something to it for it to work on GM???....
i found that i needed a longer wire with the truck alt..........reason i bought a new wire before i installed it
This mod was the best ever!! Made driving my car so much better. Fixed everything that was wrong with my car electrically(flickering lights,blowing fuses,idle,no dimming from the subwoofer, and just feels smoother all around). I couldn't be happier. If you are debating on doing this and have flickering lights etc. don't waste your time. Just do it
