The fix for my endless alternator failure's
So I probably have a short somewhere...?
However...my stereo is still sparking. Basically as I said the others blew...well I went to get some new fuses and put it back in again and it was sparking like crazy...so maybe there is a short in my stereo now..?
EDIT: took the wire going to the amp out of the fusebox...replaced the fuse, no spark. Went to plug wire back in, spark. So the short I have is somewhere within that wire...checked it in the back, looked okay, but I'll double check tomorrow. There should be no breaks in the wire along it, so where should I check for the short?
Thanks for the help everyone!
I am thinking this could be a developing alternator problem. Based on this thread:
1. I can replace my stock alternator with a junked KG3 truck alternator.
2. It appears the junked truck alternator comes with a 747 pulley. I am assuming that the stock f-body alternator also uses a 747 pulley.
3. 00pooterSS notes that pulley alignment slightly off after this mod, even with the presumed 747 pulley. Is this acceptable? Is this misalignment due to the cases being different, relative to the stock alternator, or is it pulley position due to differing shaft lengths? Is there any way to get perfect alignment?
4. Would changing the wiring harness 4 pin connector to 2 pin connector be beneficial so newer junk trunk alternators (with 2 pin connections) could be used?
Thanks.
Thanks.
I have a belt squeak issue so I just wanted someone to confirm the distance from the front of the pulley on the truck alternator to the mounting pads on the alternator. I didn't say that it is actually out of alignment, just wanted to eliminate that possibility by checking. Best I can tell it is in alignment. But I need a stock F body alternator to compare to on a bench with a truck alternator to 100% confirm. Others do not have the issue I have so it's very doubtful that that is the issue.
No you can't do the 2 wire, the 2 wire came on the trucks that have a voltage monitoring box on the battery wire and the PCM cycles the alternator on and off. Our cars don't have that function. It may be possible to wire up a 2 wire where it stays on all the time but I do not know for sure.
If I recall GM did that on the trucks to boost fuel economy by only running the alternator as much as needed not at all times.
Tony
Long story short I tested every thing multiple times and even replaced the exciter wire and connector, never could find an issue and it all started when I replaced the factory original alternator with an aftermarket one, and it was all downhill from there.
The fix.... A truck alternator. I got the idea from another board member that the truck alternator actually fits the F body cars, so I went to the junk yard and spent $40 on a used 2003 Truck 145 amp alternator bolted it in and the voltage has never been more stable.
The 145 amp truck alternator only has one simple modification that needs to be made to use it, it does not use the rear support bracket that the F body alternator does so remove the one bolt and bracket, other than that it bolts directly in, plugs directly up, and works good!! So for less money you can have an higher amperage output, more stable, more durable alternator if you go this route. The pulley was even the same, this couldn't be easier.
I am going to add a wire from the back of the alternator to the battery to help carry the extra amperage since it has been stated the factory wire isn't even enough for the puny stock alternator.
I hope this helps anyone else with the same issues, here is the link to my original thread if you feel like reading more details of the problems I was having
https://ls1tech.com/forums/generatio...ders-here.html
Identifying the right alternator:Get a 99-2003 Truck alternator (may even apply to up to around 2005?), 145 amp, 4 pin connector, the code junk yards use to identify it is "KG3". The standard truck alternator is a 105, Escalades and such trucks with a lot of electronics use the 145. When I ordered mine I told them it was a 2003 truck, 145 amp, 4 pin connector, KG3 option and they figured it out. I got mine from LKQ for $43.30 picked up.
Some more info on identifying the alternator
ALSO VERY IMPORTANT Replace the alternator connector, the single wire connector with the plastic plug in on the top, these fail and cause problems as well. Here is some information on the connector.
AC Delco part PN# PT1136 (Oreilly has another brand also for the connector, don't remember the name brand)
I got mine from NAPA so you can try going there or go to Oreilly
http://www.oreillyauto.com/site/c/se...aro&vi=1361450
I've got the alternator installed and looking to wire it up now. Just want to confirm that I only use (1) wire on part # PT 1136 where the connector is labeled (L) on the rectifier? What is the point of getting a new connector for this alternator then? Just to ensure a clean good connection? Do I just cut the red wire from the existing plug on the engine harness and solder it to the new wire on PT1136? Nothing else to do right?
You are replacing it due to the fact it is a common failure. So yes to ensure a good connection. Yes cut wire and solder on new.
You have it all right.
http://m.oreillyauto.com/mt/www.orei...1468&ppt=C0330
And everytime on O Reilly I type pt1136 this comes up
http://m.oreillyauto.com/mt/www.orei..._jtt_v_thumb=1
Are those all I need ? And will those both work??
