The fix for my endless alternator failure's
Just did this swap today and it is definitely worthwhile. A couple quick tips to help those doing the swap for the first time.
1) The nut on the truck alternator for the grounding wire is smaller than the stock alternator. If you got one from a junk yard it may not come with the nut. It is an M6-1.
2) To remove the exciter wire without damaging it, first loosen the front 2 alternator mounting bolts and the front mounting bracket bolt. Then completely remove the rear 13mm rear mounting bolt. Push the alternator and bracket forward towards the fans a few inches so that you can reach behind it. Reach behind the alternator and feel how the exciter wire clip attaches. You may even be able to look down from the top at this point to see the connection. Grab a small screwdriver and reach behind the alternator then gently pry the connector loose. It should pop right out once you have the screwdriver in the right position.
3) If you have a powerbond underdrive pulley, a 76" belt is the size you want.
01 Camaro Z28
01 Camaro Z28
01 Camaro Z28
I responded to your PM about this. I don't know of a bracket that has the rear support as part of the main bracket, never heard of that or seen it. If so you will need to modify that bracket or go buy one from a scrap yard that doesn't have it.
Take a closer look at yours, you may want to just remove the bracket and have a look. I bet you'll find it's not actually like that, if it is then we are all going to learn something new!
But X2, take a pic
1. Which pin on the alternator should I be hooking switched 12v up to on the alternator?
2. Are there any resistors required? There is no charging light on the car.
3. Do I need to run the switched 12v wire through the cut-off switch, or is there another wire on the alternator I can run to the switch that will turn off the alternator while running?
You can see it in these images.. One shows the test light touching the pin, the other shows a single wire plug, the wire that is wired in that plug is the L terminal wire. So use it for reference or buy a one wire plug and take the guess work out.
http://www.google.com/imgres?q=gm+al...:19,s:200,i:61
http://www.google.com/imgres?q=gm+al...r:80,s:0,i:327
It says is for a 2002 chevy silverado 2500. I just can't find any info to see if it is 4 pin. Thanks.
Amazon.com: Bosch AL8731N New Alternator: Automotive
ALL AND ALL VERY EASY SWAP
everyone
