The fix for my endless alternator failure's
I'm looking at eBay for other used ones since I don't have time to hit the local yards. Has anyone verified that up to '04 or even '05 will fit? Mine is from and '03 at the moment.
Another thread suggested using the Big 3 wiring kit from Innovative Wiring to handle the additional "juice" from the new alternator but $95 seems like a big chunk of change for wire.
Will it hurt anything by simply replacing the stock alternator with a new AD244 145A model and using the original battery wires?
I found one at my local LKQ for $35, although they also have a $25 core charge. So I guess this one will cost me $60.
If for whatever reason that one doesn't work, the $135 Tuff Stuff 145amp truck alternator from Summit would likely be my next shot, as their customer service rep replied to my question on origin with "We build them here in Cleveland, Ohio."
I thought there was an upgraded alternator that was in the same size case?
Someone help me out here and find a better alternator that is the same size case.
It'll work with a smaller bolt head -
https://ls1tech.com/forums/general-m...lternator.html
But there are a few options for the factory alternator (cs130d). Here's a factory case 160 amp - http://www.ebay.com/itm/NEW-LS1-CHEVY-FIREBIRD-Trans-AM-Camaro-ALTERNATOR-02-00-99-98-HIGH-AMP-Generator-/131136118260?_trksid=p2054897.l4276
you have to check the pulley on remans....it may look right but be slightly off from the stocker....so save the stock pulley
Just installed it and yes you may have to bend the power steering lines just a lil bit...wasnt much at all. I did not have to mess with the sway bar in the slightest. I also used the pulley that came with the alternator...I did not have to swap pulleys.
My voltage has never been better. My original alternator with the ac on and in drive with the fans running full blast would have my voltage down near 8 volts. Now, its a rock solid 13 volts.
For those of you who are going to say "You should have gotten one from a junkyard because its oem and its better blah blah blah" I am in Hawaii and that simply wasnt an option for me so I bought a brand new unit from Oreilly's.
Edit: Here is the link for the alternator: http://www.oreillyauto.com/site/c/de...ord=alternator
On a side note, I just ordered a 145 AMP for my truck in my sig, it has a 105 that is starting to peter out. I added electric fans and front end wiring harness from a 2007 truck, and that combined with the stereo system just isn't cutting it. Hopefully 145 is enough!!
Thanks for the info!
The pulleys are usually the same.. see my last comment at the bottom of this post
For those that asked about the pulley and the belt.. I used the pulley that came on the alternator and the stock length belt with 0 issues. Compare your old pulley to the one on the new/used alternator and if they are different use the one off the alternator you are taking off of your car and put it on the alternator you are putting in.
