The fix for my endless alternator failure's
#1261
Depends on what's there already, but the wire from alternator to battery is what usually needs upgrading when kicking up alternator capacity.
#1264
#1265
The powermaster 48237 DOES fit our 4th gen f-bodies. It's just a matter of re-clocking the rear housing 90 degrees clockwise and it fits perfect.
The following users liked this post:
LilJayV10 (02-26-2024)
#1268
Duralast, eh? I put my first Duralast 105A alternator on the TA around 300,000 miles ago and with the lifetime warranty, I've probably swapped them out a half dozen times. That 145A was the way to go apparently. I put the powermaster 220A recently and have not seen a drop under 13 volts since!
#1271
Do you remove the long bolts that hold the front/rear case together, rotate the rear case and bolt it back up?
#1273
I got it installed and drove it this evening.
Did not fix my problem.
So that's 3 different alternators, one reman stock, one reman truck alternator, one Powermaster 220amp truck alternator
Big 3 upgrade
replaced L terminal connector.
Same result, 5500rpm, alternator stops charging.
To say I'm less than thrilled would be an understatement.
Big 3 upgrade
#1274
What’s the catalyst to all these bum alternators? Under drive pulleys? Sound systems?
#1275
Stock diameter ATI balancer, stock diameter alt pulley, Katech manual tensionor, Gates belt.
It has a 750wx5 JL amp with 10 CDT sub.
Dual 525lph pumps.
Other than that the electrical system is stock 2000 Firehawk.
The radio was off last night when I drove it.
Last year I used an oscilloscope and monitored battery voltage at the battery and the L terminal at the alternator.
IIRC, the L terminal doesnt have a full 12v on it, I think if it does, it will burn something up. It's been long time since I read up on it.
I'm thinking running a temporary wire to the L terminal, with the needed resistors to drop the voltage down to whatever it needs to be, through a toggle switch and see how it acts.
In the instructions on the alt, it says it can be a one wire alternator. I don't know if it referring one wire on the 4 pin plug or just the big wire that goes to the battery. I don't remember seeing a way to "make it" a one wire.
Dual 525lph pumps.
#1276
LS1Tech Administrator
Received 1,713 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have my '71 set up this way (one wire, Powermaster); it's an older 10SI style unit but the principles are the same. Someone had already modified the harness for this prior to my ownership, otherwise I would have kept the original multi-wire configuration. I don't have any low voltage condition, even without the remote voltage sensing (again, because Powermaster is a quality unit with great output), but I do have to disconnect the battery when the car is not in use because of the drain of constant field voltage in this arrangement. I only drive the car maybe once per month in the on-season, so it would be very hard on the battery to leave it connected all the time in this configuration.
LilJayV10 (03-04-2024)
#1278
I wanted to come back in here with an update.
I've changed back to the stock OS(upgraded 2 bar) and that took care of the problem. I had been using a Tahoe FF tune since last fall. The car never drove as well on the Tahoe OS, for whatever reason.
This afternoon I went back to the stock OS because I started logging airflow follower/cracker PIDS to try and fix the problem of it not returning to idle correctly. I found absolutely no cracker activity and very little follower activity, even though I had put those tables back stock using the F body values.
After going back to the 2bar Fbody OS, I had a lot of follower/cracker actiivity and you know what?
It holds 13.8v all the way up now.
When I went to the Tahoe O/S, in the SYSTEM>GENERAL>SYSTEM OPTIONS tab, I changed those to match my stock OS. With the Tahoe O/S, my dash was lit up like a Christmas tree which always bothered me. With me having to scale my tune for the injectors, the FF adder spark table was really of no use to me because you can't rescale the adder table. The only real benefit was the sensor itself that would change the stoich value.
For me, for a long list of reasons, will be sticking with the 2bar upgraded OS and get a Innovate WB setup that shows ethonal content so I can change the stoich value in the tune if needed.
I did go back in the logs(I log it almost everytime I dirve it) and verified with the stock alternator and cables, it stopped charging around 5500rpm. It did it with the Big 3 upgrade too.
Why it acts the same way with the Tahoe OS, even with the aftermarket alternator I don't know and at this point I don't care.
#1279
^ Interesting update, that's not something I would have expected but I guess it shouldn't be too surprising considering everything else you have already tried.
"Once you have eliminated the impossible, whatever is left, however improbable, must be the answer."
It's great that you got it fixed. I once had a very odd charging issue with my '98 Z28, tried tons of fixes/diagnostics to no avail, and ended up with a solution that some folks insisted "couldn't possibly have been the source of the problem" - yet it solved the problem, and it has stayed solved for nearly 20 years. LOL.
Glad you've got it working now. I understand how frustrating it must've been, and how rewarding it feels when it's over.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
LilJayV10 (03-07-2024)
#1280
I ordered a Holley EFI alternator connector/wire with the resistor and was going to hook it up to a switch 12v next. That probably would have fixed it, but I would have never known what the issue was.
When I changed the OS, in the back of my mind I was "hoping" it would somehow fix the issue but wasn't that hopeful.
But honestly, unless there was something wrong with the PCM, there was literally nothing else it could be.
Working on a problem on and off over months, it's easy to lose track of what you have done and when. Luckily I datalog a lot and I'm able to go back and look.
I am really big on diagnosing and figuring out a problem instead of just throwing parts at it and see what sticks.
I don't feel bad about spending $400 on an aftermarket alternator anymore, even though there is a good chance that the reman truck alternator would have fixed the issue.
Regardless I'm happy it's over, lol.
Y2K_Frenzy (03-08-2024)
