i cant figure this out for my life
ok i know ive posted about this b4 but im having some big problems....once again something under the car is hitting...i cant figure out what...i shaved down my kmember more the other day and i bogged today and i got thumping again....i have about an inch and a half of clearance everywhere around the y pipe....it does sound like its on the driver side....this just recently just started again...its been fine sine Oct. until the other day....WTF IS WRONG???? should i get a bracket wielded in to keep the pipe from hitting and go from there or am i missing something?? HELLPPPP!!!
Do you know it's your exhaust? Look for marks on the frame of the car.
Does it happen when you shift hard? Could be a broken tranny mount. But if you say it happened, then went away, then happened again thats probably not it.
You're ypipe is likely hitting under the floorboard by the drivers side. Just weld a valve spring between the floorboard and the ypipe. It will make you're exhaust more solid. Worked for me.
i think its under the seat i think...not sure though...and the valve spring idea...definitely a good one...when u say valve spring do u mean like one out the engine or a different "valve" spring(sorry guys im still learnin) would a muffler shop have a spring like that because i dont have the knowledge nor the tools to weld myself? this **** just chaps my ***.....
ok...i did that in first and it didnt do anything...i dunno if its different from reverse as far as movement...just thought i would let you know
ok...feel free to flame me for this one...what part is the torque arm...is that the black part where the ypipe starts to go inward towards the middle?
ok well i put it in reverse and torqued it....and the pipes moved and got somewhat close, but didnt hit...i couldnt hear any actual hitting but i had a friend come out and check it with me and he said he thought that it sounded like it was farther up front, but that he wasnt sure...he also said it looked like the pipes were close even though they werent hitting..could the pipes move more when im driving causing them to knock or do you think its up front with the headers?
yeah the pipe will move a lot more than the headers due to the fact its father down line, i little wobble up front could be a big wobble 3 feet back. when u put the drivtrain under a torque load they will move a LOT more than when you are sitting still. im willing to bet its hittin that cross brace welded to the frame right under the driver side. u did grind down the kmember right?
well i went to the muffler shop and they couldnt figure out exactly what it was hitting. they told me the best thing for me to do would have a chain connected to the engine and wielded to the frame to keep it from moving? they said they dont do it but that a shop down the street should. should i do this instead. they told me i should pick up some torque since i wont lose it from movement in the engine...
LOL! I would not do that. If I were you I would try the valve spring idea first.
