Is the chrs1313 Ram air worth it?
try a search in the lt1/lt4 section
most give gains in mph do to that being the true hp gain being seen...it takes traction out the equation...plus a 2mph gain will transfer to a different ET for a 9 second car vs a 12 sec car...
currently my car is around 10.0 sec flat and it takes around 18-20rwhp to drop .1 tenth...but a 12.0 car only needs 9-10rwhp to drop a tenth...
hope this helps some
I received my AC-version of the Chris1313 Ram air setup from speedinc.com a few months back, but my car was in the shop!
I just got my car back, so I found the box and opened it up.
It's a beautiful piece! I'll post pictures later.
My only question is that I have seen people talking about the 'extension.'
Is the A/C version of the ram air supposed to come with an extension? I saw no extension in the box...
Thanks in advance!
Thanks in advance!
There is an extension with the non ac version...
Thanks guys
Nothing ground breaking or earth shattering but a decent pay off for the work i put into it over the last couple months
Previous old best on motor was
60' 1.74
1/8th 7.856 @89.12
1/4 12.309 @ 109.73
todays new best was
60' 1.674
1/8th 7.654 @90.28
1/4 12.030 @ 111.87
Tried to make a few nitrous passes to see if i could get that 10 second pass I i'm looking for but the track just wasnt there. Tried tire pressure adjustments and window switch adjustments and as soon as the gas came on it'd blow the tires off.
New mods include front lower a-arms, chassis mounted tq arm, ls1 lid and chris1313 ram air and switched from a shark nozzle to a no2 outlet plate kit.
