Are headers proven? Anybody with headers plz hlp
Old Jun 16, 2010 | 05:24 PM
  #81
z99ls1's Avatar
Restricted User
What are full bolt-ons though?
Old Jun 16, 2010 | 05:31 PM
  #82
Gaunt's Avatar
Full exhaust (headers, ORY/ORX or Catted Y/X pipe, cutouts or dumped/catback setup).
Intake manifold
Underdrive pulley
Lid
Ported/bigger throttle body
Bigger MAF
uhh I'm sure I'm forgetting something.
Cold air intakes generally (not ricer ****, but actual functioning intakes that scoop air from underneath the car)
Depending on who you ask, gears and free mods are thrown in that mix.
Originally Posted by orangeapeel
Only loss that you may feel is what was discussed earlier. Down low.
Basically this.
To add on to this, it would be a misrepresentation to say headers (at least long tubes) are only going to help your peak HP numbers on the dyno. That's simply not the case. There is power to be had at many places under the curve, and specifically, in the power band.
Old Jun 16, 2010 | 05:36 PM
  #83
oddwraith's Avatar
Yeah some people consider clutches and stalls as bolt ons also. So an a4 should have a stall to be considered full bolt on, but everyone's "full bolt on" seems a little different. For example some people would say to not bother with a maf until your up over 500hp (beyond bolt on hp).
Old Jun 16, 2010 | 05:37 PM
  #84
lemons12's Avatar
DO YOU HAVE A CONVERTER YET!?!?! This was ignored when I asked earlier.
  #85
z99ls1's Avatar
Restricted User
I will try to make a before and after video with the headers and my buddies lt1. We are pretty much side by side now so I will make a vid before and after and maybe we can end the debate
Old Jun 16, 2010 | 05:40 PM
  #86
thunderstruck507's Avatar
you already have the headers...and from the looks of your sig in the past you have installed a ls6 intake
would you do the ls6 intake again? because even the skeptics are admitting there should be AT LEAST a 10rwhp gain...that is the average for what the intake should have given you
you have a lid, intake, and what I'm guessing is the slp ram/cold air that force feeds the airbox, so why choke the engine on the other end? depending on how your car responds, the headers could be worth about the same as all 3 of those mods combined
it sounds like you are looking for an excuse to be lazy more than anything
Old Jun 16, 2010 | 05:41 PM
  #87
lemons12's Avatar
There isn't much of a debate really going on. Just some more ignorant people claiming stuff and some of the more veteran tech residents telling you what is facts. You have to be able to looks through the bull **** posts and decide what is opinion and what has been proven/has data to prove point/etc etc etc.
Old Jun 16, 2010 | 05:42 PM
  #88
z99ls1's Avatar
Restricted User
So I am pretty close to having a full bolt-on car. And no I don't have a converter. This rearend has to last me awhile lol. Ill get one down the road when I eventually do a cam swap
Old Jun 16, 2010 | 05:44 PM
  #89
lemons12's Avatar
Blah... Should do a converter before anything else. IMO at least.....
  #90
Ls1Rook's Avatar
Headers have been proven already, me being one of them Lock it up already lol.
  #91
a converter will do you more good than anything else you have done or can do to the car as far as bolt ons
it's not really going to be any harder on your rear either, get one ASAP
Old Jun 16, 2010 | 05:48 PM
  #92
z99ls1's Avatar
Restricted User
Ha I aint lazy lol. i want to do the headers. Got to wait for a good time where im not on call and am not working and they will be in. And yea I would say the ls6 intake made a good difference. I would say at least a tenth. I could feel it. I ran a 13.5 stock with 2000 ft DA 58 degree weather and a little chilly. and than I went back with mods in sig and ran a 13.4 with a 4000ft DA in 85 degree humid weather. You guys are def making me want to do the headers now. I think I will get good gains. 99% of the people are telling me its deff going to make my times better.
Old Jun 16, 2010 | 05:57 PM
  #93
odarabla's Avatar
Intake manifold
Underdrive pulley
Lid
Bigger MAF
Basically this.
No under drive pully, stock LS6 intake (my car came stock with the LS6 intake) with a SLP lid, Full exhaust (offroad headers, uncated ORY, Magnaflow catback, SLP MAF
Old Jun 16, 2010 | 06:14 PM
  #94
Gaunt's Avatar
Originally Posted by odarabla
No under drive pully, stock LS6 intake (my car cam stock with the LS6 intake) with a SLP lid, Full exhaust (offroad headers, uncated ORY, Magnaflow catback, SLP MAF
I'm not quite sure what you are trying to say with this
Converter should be one of the first mods, I don't understand why this isn't a big *** sticky in the auto section here :/
Old Jun 16, 2010 | 06:45 PM
  #95
batman_ls1's Avatar
well i say LT's and a 85mm TB are a big help but i know it varies i was running a 14.4 bone stock and with just LT's, ory with 3inch straight back and a 85mm TB i ran a 12.9 with a elevation of 3075, and the da was 5600 so i say hell yea to LT's and a TB if u have the money
Old Jun 16, 2010 | 07:27 PM
  #96
odarabla's Avatar
Was explaining my boltons to the guy. Thats what I meant by that. and meant to say my car came with a LS6 intake stock so that means that I didn't change the intake until after I did the heads cam swap.
Old Jun 16, 2010 | 07:31 PM
  #97
got-a-ls1's Avatar
gained 30 rwhp from headers and magnaflow on a mustang dyno....
however track times still suck because of a stock converter... taking care of that with circle d here very soon.
Old Jun 16, 2010 | 07:48 PM
  #98
odarabla's Avatar
I know that Circle D is a very good converter but you might check into PTC torqe converters. I've used them since I was a Full bolt on car to a H/C/I car and now a Built 402ci th350 Z28. They will custom build you a converter. A LS1 converter built for your setup will cost you $475.00. **** man my racing 8" converter for my th350 only cost $750.00. Not bad for a custom built converter to my specs.
Old Jun 16, 2010 | 08:24 PM
  #99
disc0monkey's Avatar
Originally Posted by JonCR96Z
The 98-00 has a rolled steel manifold. The 01-02 has cast iron.
my car has 241 heads and cast iron
Old Jun 16, 2010 | 08:26 PM
  #100
lemons12's Avatar
I agree... PTC=the ****!
