new mods what else do i need
Old Jun 19, 2010 | 08:56 PM
crazygn's Avatar
Default new mods what else do i need
I run a bone stock 98 engine in my notch mustang. It ran a 12.07@114 w/ 60' 1.74 in the heat a few weeks ago. Here are the bolt ons
1 3/4 long tubes
4'' air intake
th400 with 4000 stall
3:55 gears
28.8 injectors ls6 i guess
ls1 intake stock TB
Question is what do i need for my new mods.This is what i just bought
ls6 intake w/ ported stock TB
torquer v3 cam
1-will the injector be ok
2-i also read that i should have new rod bolts
3-What are my options with valve spring
4- what kind of power gain should i get for these two mods
Old Jun 20, 2010 | 12:00 PM
crazygn's Avatar
anyone run the v3 then and like it
Old Jun 22, 2010 | 01:24 PM
crazygn's Avatar
where did everyone go
Old Jun 22, 2010 | 01:36 PM
MonmouthCtyLS7's Avatar
LS6 coolant lines for the LS6 intake...or you could flatten the ls1 lines, your injectors should be ok...id ask tsp what springs work best for that cam..
Old Jun 22, 2010 | 01:40 PM
crazygn's Avatar
will the ls1 fuel rail work on the ls6 intake
thanks for the reply, i knew someone was out there haha
Old Jun 22, 2010 | 02:11 PM
bayer-z28's Avatar
Git it tuned asap.
And if it's a 98, yes, you will need better rod bolts.
PRC Dual Gold Valve Springs are good to .650 lift. Got em on my Torque cam @ .640 lift. LS6 intake is fine. If you can hog out the mouth and squeeze an 80mm TB on there, do it.
I went from 336/346 with bolt-ons to 414/372 with my torque cam and an ok tune. Just to give you an idea. And I'm still running a 78mm LS1 TB on an LS6 intake.
Old Jun 22, 2010 | 02:27 PM
crazygn's Avatar
they are the springs i was looking at so thats good.
Are the 28.8 injectors good to feed the engine with this cam, what will 28.8's support. I thought i seen over 400 rwhp but could be wrong
Old Jun 22, 2010 | 02:34 PM
Yup......
Old Jun 22, 2010 | 02:58 PM
bayer-z28's Avatar
Not sure on injectors, but people run SVO injectors. 32lb/hr maybe?
