wich is better?
Old Jan 15, 2004 | 08:13 PM
Q8CamaRo's Avatar
Default wich is better?
i wanna ask about the GMS M.A.F and the SLP M.A.f
wich is better and much would it give on the rear wheel?
another quistion .. i removed the net from the stock M.A.F then i checked if its wokrking or not a code says .. low input cercuit.. wat is this?
thanks
Fahad From kuwait
Old Jan 15, 2004 | 09:37 PM
WS6FirebirdTA00's Avatar
descreen your stock maf and dont waste money on those maf's for one like i always say i will never buy another slp thing, their maf sucked and they wouldnt take it back, however return policy says they would. it will throw off your computer so bad, just descreen that stocker. if u change that maf your tranny will be at threat also
Old Jan 15, 2004 | 09:46 PM
Q8CamaRo's Avatar
ok but is the meaning of 'low circuit input'?
Old Jan 15, 2004 | 09:49 PM
Q8CamaRo's Avatar
ok but what is the meaning of 'low input circuit '? that code was shown when i descreened the stock maf
Old Jan 15, 2004 | 10:03 PM
hmmmm u know i think my frineds threw the same code. try and clean off the MAF sensor, it may be going bad. u know i put my old slp maf on my frined 98 and it worked better than it has on any 99-02's it might be ok for you now that i think of it...if u have to replace that maf. his threw taht code and ended up going bad after about 6 months
Old Jan 15, 2004 | 10:12 PM
Q8CamaRo's Avatar
hmmmm u know i think my frineds threw the same code. try and clean off the o2 sensor, it may be going bad. u know i put my old slp maf on my frined 98 and it worked better than it has on any 99-02's it might be ok for you now that i think of it...if u have to replace that maf. his threw taht code and ended up going bad after about 6 months
where is that o2 sensor is it on the Y-pipe? .. i removed the cats
Old Jan 15, 2004 | 10:19 PM
**** my bad man i meant maf ill fix it
Old Jan 15, 2004 | 10:20 PM
just get some contact cleaner to spray on the resistors, let it dry and reinstall. sorry about the goof up again, its fixed
Old Jan 15, 2004 | 10:31 PM
Q8CamaRo's Avatar
thanks alot .. do u recommend to port the stock maf?
Old Jan 16, 2004 | 12:36 AM
jrp's Avatar
jrp
SN95 Director
stock screened MAF, more then enough to supports a decent h/c package.
Old Jan 16, 2004 | 06:07 AM
i woulnd port it cause then u get in to too many tuning issues
