Radiator Options
Old Jul 7, 2010 | 09:57 PM
areax's Avatar
Default Radiator Options
I've been looking around on the forum to find different brands of radiators that I can put on my 02 SS without much luck. My stock one is leaking so I'd like to come across a new one. I've been reading a bit about the LT1 radiators being used on the LS1. What are the advantages of the LT1 radiator over the LS1? Anyone have any insight?
Thanks.
Old Jul 8, 2010 | 10:53 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The LT1 radiators are a little thicker than the LS unit
Old Jul 8, 2010 | 08:07 PM
areax's Avatar
Ooh okay.. I might try to come up with one of those and see how it looks.
Thanks man.
Old Jul 8, 2010 | 09:39 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Here's some info for you:
https://ls1tech.com/forums/generatio...ator-easy.html
Old Jul 8, 2010 | 10:03 PM
DrkPhx's Avatar
Noticeably thicker and cools much better (both engine & trans) compared to the LS1 radiator. I switched to one 3 years ago with no problems.
Here is a pic comparing the two cores.
Attached Thumbnails Radiator Options-lt1-vs-ls1-radiator-core-comparison.jpg
Old Jul 9, 2010 | 03:12 AM
areax's Avatar
Thanks for the info guys.. I'll definitely see if I can pick up an LT1 radiator.. might be able to get it a little cheaper than a replacement LS1 radiator as well..
Old Jul 9, 2010 | 04:04 AM
davidws6's Avatar
Default 2 " thick core All Alum Rad.
This is what I went with. Had to modify the top plastic piece for the larger tanks. Other then that, fit like a glove and no problems.
http://cgi.ebay.com/ebaymotors/NEW-A...Q5fAccessories
Suppose to be made in his shop somewhere up around Chicago.
Old Jul 9, 2010 | 12:06 PM
Z28/2002's Avatar
Good comparison pic
You remember the part number for it?
Old Jul 10, 2010 | 02:45 AM
areax's Avatar
Pretty nice piece.. I'll probably end up going with the LT1 radiator since it's a little cheaper but thanks for the info though. Hopefully this thread will help someone out in the future looking for a one.
