FAST 102 too big?
Old Jul 17, 2010 | 05:09 PM
Egg1456's Avatar
Default FAST 102 too big?
I am going to do a heads cam intake swap with either a thunder racing trak or raptr cam and ported ls6 heads. Should i just get the 102 mm or should i do some searching and find a fast 90 or 92?
Old Jul 17, 2010 | 05:25 PM
99SSJarhead's Avatar
Honestly, a 90/92 set up isn't going to be that much cheaper than a 102 set up in a lot of cases and they are harder to find now that they aren't in production anymore.
If the money isn't an option, just go with the 102, otherwise save up and stick with the ported ls6 for the time being.
Old Jul 17, 2010 | 05:33 PM
Egg1456's Avatar
well i have an ls6 intake on it right now figured while i was changing out the heads and came id upgrade that too
Old Jul 17, 2010 | 07:24 PM
garygnu's Avatar
you can get a used fast 92 intake for less,and you will need a different fuel rail for the fast 102 intake.
Old Jul 17, 2010 | 09:46 PM
peterlawl84's Avatar
If you are patient, you can find a good deal on a ported 92. As already mentioned, the 102 and tb will run alittle more and then you have to buy a new fuel rail, so the total cost adds up quick.
Old Jul 17, 2010 | 11:26 PM
bww3588's Avatar
the 102 is not too big. its just fine for a stock LS1 engine. it was designed to be used on stock LS1's all the way up to wild large cube solid roller engines. this is why the 78/90/92 was discontinued.
Old Jul 18, 2010 | 12:55 AM
*02WS6TURK*'s Avatar
Where exactly are you guys seeing the Fast 90's for sale used? I'm in the market for one...
Old Jul 18, 2010 | 12:59 AM
bww3588's Avatar
ive seen them going for 550 for an intake and TB
Old Jul 18, 2010 | 01:05 AM
Where would this be?
Old Jul 18, 2010 | 01:07 AM
bww3588's Avatar
Parts classifieds. not typical, but that is the lowest i have seen. you just gotta be patient, they will come around.
Old Jul 18, 2010 | 01:14 AM
Keep your eye out for me...there's a finders fee if you locate one!
Old Jul 18, 2010 | 03:50 PM
Egg1456's Avatar
ill be looking for one too then. the 102 seemed a bit much for what i wanted
