Can't tell if my exhaust is hitting.
STF Veteran
I just installed Pacesetters and a ORY and my car doesn't feel any faster. I notched the k member so I don't think it is hitting there. It makes a small thump sometimes at take off. And it feels like someone is under my floorboard playing a drum roll at low RPM's. Is that the y-pipe hitting the floor board or is that my engine vibrating the car? What does the y-pipe hitting the floorboard sound like?
STF Veteran
Originally Posted by Revelation222
Yeah, its your y-pipe. I wish I would have never bought that POS, but oh well... I just put heater hose between the Y and the floor pan in two spots with band clamps for now. Works great but I dont know how long they will last.
I used the heater hose for my y pipe also. If you know someone who can weld or have a welder yourself and get a hold of an old valve spring (or even new) weld a valve spring between the drivers side of your y pipe and floorboard. You'll get a lot less vibration and your exhaust will sound more solid. Welding the fittings also helps. Doing all of the above actually changed the nature of my exhaust. In a good way.
Do you have any pics? I don't exactly understand how you did yours. Or if you could try to explain it better for us slow people.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Just get some 1 1/2" to 3" heater hose, cut it into 4 inch sections (I only needed two pieces). Then split the hose long-ways, you can use a utility knife or box cutter. Then look under the drivers side of the car. Mine was hitting on the first bend off of the header and also about 2 ft down from that spot on the same pipe. Stuff the piece of hose in between the pipe and the floor pan on both spots and then use 3 1/2" - 4" band clamps to secure the hose to the Y-pipe...Then go to the nearest side street and have a little fun
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
STF Veteran
I know this is probably a stupid question but, did you use a rubber heater hose or metal? Forgive the stupidity.
Edit: I think it just clicked in my head. I was thinking all this time that you used rubber hose and stuffed it in between the ORY and the floor pan. I didn't realize that you cut your y-pipe and replaced it with heater hose.
STF Veteran
Originally Posted by 14u2nv
I tried this too but I am using 3.5 inch worm style band clamps and I can't keep them tight. Eventually they work their way lose and I lose the hose. I have even tried loctite. I will figure out something this off season though.
