True dual vs. Y pipe
reasons:
- better ground clearance, although its still pretty low
- can run the torque arm i want which is a spohn to get the mount off the tranny
- less weight
power between duals and a GOOD ypipe will be about the same. and ive never heard ANY exhaust on an ls1 that sounds better than mine. and yes ive heard duals, and i would consider then equal, but not better.
heres a pic of my setup
its 3" ypipe and 3.5" out of the y collector
1. Is it dumped? or does it go over the axle?
2. Does if feel stronger than the old setup, or have you dyno'd again?
3. How does the interior noise compare to the old setup?
THanks
Scott
gomer,
1) dumped before the axle
2) i would say i gained a good bit. its hard to tell with the power levels im at since i break the bfg drags loose at anywhere under 60, but the butt-dyno says its a little stronger. havent dynoed yet, im probably gonna wait until i swap cams and get it tuned to dyno again.
3) as for interior noise, louder at idle. i had to fix a couple loose panels in the back that would vibrate so now all you here (and feel) is the exhaust. it has one of the meanest sounding idles ive ever heard, even with the "small" cam i have. cruising it is actually quiter inside the car than before.
My setup is much much much louder than a stock car with the same header-back system, like Priscilla's. On her car it sounds like stock. On my car I have a super deep tone and it has a lot of volume.
my buddy has a d-1 on his cobra with LT's, offroad x, and bassani exhaust and you cant even hear the exhaust at idle
thanks man
your dual setup is way up there on my list as well
Thanks, but you rode in it on its WORST day, with the hesitation ruining the experience. Problem has gone away.
Next time....
Here's my crap....
PIC: http://home.att.net/~carlos.ramirez1...2/site1007.jpg
SOUND: http://www.eadperformance.com/sounds/3test.wma
