Is throttle body coolant bypass worth it???
Point being, it doesn't really matter. You're not going to know the diff one way or another.
but i still wont do the mod. Trending Topics
http://www.bmrfabrication.com/tb-dyno.htm
i dunno where THEY got their 6.3 hp from.
Mahmood
Mahmood
http://www.slponline.com/view_produc...RTNUMBER=23065
Later all.
and the air going into the engine cooler.
and every 10* intake air temp. is equal to 1 octaine point higher
so it will help lower detonation.
and the under the hood temp dose not affect the TB temp very much
and not at all when driving, air is moving through the engine bay
and cooling it down.
My intuition tells me it's a lawsuit stomper....just in case it sticks on someone and they go flying down the road w/ no control. That would not bode too well for GM.
you dont need it to be heated.
aircraft have their carbs, and TB. heated because their flying up
there where it is -40* and a lot cooler.
and it dose heat the air up some,
in test i have seen as much 135*F. (in extream testing) diff.
the TB. is aluminum and a great heat conductor, so it will conduct,and release
heat if it is present.
if the bypass is done the only heat that is present is from the intake manafold
and the ambient air,and the manafold is composit so it dont conduct heat
as much,and the air in the engine bay dose not get that hot( if no exhaust leaks, and enginebay vents are not stopped up) maybe when at a light or in heavy traffic, but on the hwy the air is moving through the enginebay pretty good so it dosent get that hot.
i did my TB bypass soon after i got my car, and i did befor and after testing
and there was a pretty big diff.( with laser temp gun) an average of 63*F.
diff. can even feel the diff.
cooler and more dense air charge,= higher C/R, and helps prevent detonation.
But then there's the air filter which can stop it in the first place but not well for moisture...
Think about a vaccum cleaner, it constantly sucks in alot of air, the same goes for the LS1 which also depends on the speed and the type of induction intake setup (from the opening to the throttlebody)
so the faster you go, the faster the air will be sucked in at a given RPM which in cold icing conidtions can cause a icing hazzard which would means your losing power before you noticed it.
Say you go from location A to location B for a short break, then back in the car to continue to location C, the engine keeps cutting out due to lack of air everytime you attempt to speed up to speed.
Would you rather have more hassle if this happened or none at all if it was prevented in the first place by throttlebody heat and that means getting out of the car into the cold to check it out?
There's an thick gauge steel wire cable going from one of the top coolant balance pipes to the PCV which is for heat also.
As you can see in a recripiocating engine operation for aircrafts, they have carb heat for the carb and also for throttle bodies for fuel injected engines too, it also states icing can occur even when there's no icing present outside. The icing can cause a loss of power when it builds up in the venturi and reduce the volume of the air coming in and it will increase icing buildup.
As GM tests these cars from the Death Valley to extreme colds as in Alaska, they have to ensure it will work in all climates as possible to see if the A/C is good enough, can withstand extreme temps, and extreme colds without problems for defogging and heating purposes and more.
Kinda like if it can go from FL to AK roadtrip for endurance testing.
My car already has it done.
