Removing A.I.R. System
Old Sep 26, 2010 | 03:57 PM
RrCoX22's Avatar
Default Removing A.I.R. System
Tons of threads and plenty of searches... for a '01 Z
Driver side back by the junction what is the "T" fitting junction being held onto? I see a bracket and took one nut out and the bracket seems to bend around the backside of the head. Does it pop off that bracket? Also the solenoid seems to just be bolted to a bracket as well neither of these seem to be budging. My huge hands need to know what they're doing as I can barely see anything.
Old Sep 26, 2010 | 04:59 PM
OMGls1jz's Avatar
good question i never figured this out as well
Old Sep 26, 2010 | 05:16 PM
andystaiger's Avatar
There is one more nut holding it on.. (on the very back super close to the firewall)if it's where I'm thinking..
It's bigger than the 1st one you took off..
mine is a 2000 though..
It MIGHT be just a tad different..
Old Sep 27, 2010 | 12:12 AM
milburnr's Avatar
I just took mine off today. I tried unbolting the brackets but realized one must be bolted to the rear of the manifold. Not going there so... I popped the solonoid off the brackets with a flathead screwdriver. wasn't hard to do. And then I plugged up the vacuum line going to the back of the intake.
Old Sep 27, 2010 | 12:42 AM
rooster18's Avatar
i am doing this now because of header swap and other stuff. i have the same delima. i couldnt find anything about it after searching. does anyone know where a full write up is on this???
Old Jan 17, 2011 | 01:58 PM
SIK GTO's Avatar
Me too ^^^ I need some specific info. I found a post that said that the LS6 intake doesn't have AIR plugged into the back. About to do OR LT's.
Old Jan 17, 2011 | 02:14 PM
armyboyatc's Avatar
There is a full write up in the stickies. Check there.
Old Jan 17, 2011 | 03:53 PM
sjsingle1's Avatar
the bolt for the bracket is on the back of the head it is a 15mm........it is a PITA but doable
Old Jan 17, 2011 | 03:55 PM
sjsingle1's Avatar
Old Jan 17, 2011 | 03:57 PM
sjsingle1's Avatar
thats the T on the back on the mani......its easier to cap the nipple on the AIR solenoid above the valve cover on the rear drivers side
