PCV and hoses rotted out
Old Oct 8, 2010 | 04:25 PM
  #61
NBMZ/28's Avatar
Originally Posted by sjsingle1
170$ ?? i got mine from scoggins for waaaaay less......the previous style used a pcv in the hose to the intake.......the preforations in the new style act as a catch can within the valley cover.......so no need for a external pcv...........still not sure on which way air flows in the hoses.......previous to the LS6 vc install .........oil mist (gunk) accumulated in the TB from the valve cover hose which indicate that air flowed into the TB......have not looked at the TB since the install of the LS6 vc
The cover from TR comes with a new gasket which is around 47 bucks, button cap hex bolts, and the hose.
Old Oct 8, 2010 | 06:48 PM
  #62
crainholio's Avatar
Originally Posted by Unertl42
HAHA, no, just think of it as extra time you get to spend doing unnecessary things to your car. Thus making you better than 90% of the population
Flinging abrasives every which-a-way with my engine open is on my Top 5 Things I'll Never Do list. I'd rather have my ***** flattened with a wood mallet.
And before anybody jumps on to tell me how misguided I am, don't bother. Your engine, your call. This one's mine and it ain't gonna happen.
Old Oct 9, 2010 | 12:49 AM
  #63
WagnutSS's Avatar
i got that ls6 valley cover coming in soon, thanks a ton for all the info, i will let yall know how the install goes so we can clear some **** up, well for an 02 camaro anyways.
-Austin
Old Oct 9, 2010 | 03:26 AM
  #64
sjsingle1's Avatar
LS1 blocks need the cut.......LS6 blocks dont
Old Oct 9, 2010 | 03:33 AM
  #65
sjsingle1's Avatar
LS6 cover.......scoggins....80$ includes gasket and bolts
LS6 steam tubes (2) scoggins.....30$ (each)
OPSU 80$....dealer ..........yes i broke it
knock sensors (2) auto zone.....45$ (each)
hose from VC to intake...dealer....3$
button head VC bolts ......ebay....15$
button head bolts for steam tubes.....ace hardware......10$....(ouch)
Old Oct 9, 2010 | 03:35 AM
  #66
sjsingle1's Avatar
the KS wells were full of water
Old Oct 10, 2010 | 01:09 PM
  #67
joecar's Avatar
I guessing the LS2 valley cover the same design underneath as the LS6? So, you're saying with this you don't need a catch can? Just trying to clear things up.
here's another pic to help your cause 01ssreda4, I'm with you bud
This is how mine is setup on my LS2, but its the same as the LS1/6 with the LS6 valley cover. For a LS1 you just need to block off the rear fittings.
The LS2 valley cover is different than the LS6 cover...
the LS2 cover does not have the holes for the knock sensors, as both your pics show... compare with pics in posts #41, #51.
this matters if installing on an LS1.
