Just Installed LS6 Intake and P+P TB
What I'd do is remove the throttle cable from the TB and move the TB lever back and forth and see if the TB feels like it is sticking at some point. If it is you can remove your TB and look in it and see what is going on.
You can barely even tell with a 25hp gain let alone a 5hp gain. Trending Topics
I did headers, ported TB and a tune all at once. But my car was running very lean so I went from a 101 trapping car to a 109 trapping car. That was a night and day difference LOL!
The sticking throttle you are experiencing is probably the throttle blade. I never had the issue with the one I did for the LS1, however I have on other TBs (TBIs - yes, I'm old). You can try two things to fix it. First pull the TB and loosen the to screws that hold the blade in place. Be careful, the porter may have used loctite on them. Once loosened, you may notice some play between the screws and blade. try positioning the blade and tightening the screws so the blade doesn't catch. If this doesnt work, you can pull the blade and lightly sand the areas that are catching.
If the blade isnt the problem, it is probably the way the shaft was reinstalled after porting. Its been years since I did mine, so I dont remember exactly, but its very touchy on reassembly. Maybe somebody else can chime in
When I did my LTs and TDs (OR X) I felt more top end
The tb should improve throttle response a lot, make it feel snappy when you drive.
