Using 85mm MAF on 99 LS1 car questions
Old 10-05-2010 | 01:55 PM
Logic's Avatar
Default Using 85mm MAF on 99 LS1 car questions
I have read a few post about the stock GM 85mm truck MAF is a good upgrade for other LS1 cars. I have a 99 TA and wanted to know will this stock GM 85mm truck MAF plug directly into my cars harness or will I need something else?
Thanks,
Old 10-05-2010 | 02:31 PM
jimmyblue's Avatar
Moderator
You will need a pigtail (or adaptor) and tuning, and you
may as well descreen it. See Casper's for the wiring bits
if you don't want to molest a junkyard truck and do your
own soldering.
Old 10-05-2010 | 03:00 PM
Logic's Avatar
ive been soldering since i was 8 lol.
Old 10-05-2010 | 03:04 PM
01SS99red's Avatar
It s a very easy and good mod. But make sure you get a good tune.
Old 10-10-2010 | 11:10 AM
NitrOmm's Avatar
At the risk of souding like a " Bone Head" ... can you direct me to where I can get the pigtail or adaptor for my 99 WS6.
Old 10-10-2010 | 11:40 AM
dgcustomz's Avatar
here ya go..
85mm MAF 3 Wire To 5 Wire Adapter
[CAS108100] $30.95
Casper's Electronics 3 Wire To 5 Wire MAF Adapter
When converting your LT1 or LS1 from the factory 3 wire MAF to an 85mm 5 wire MAF, you will need this MAF adapter to attach to the factory harness. This will allow the built in IAT sensor in the 85mm MAF to be functional in place of the detached oem factory sensor.
This will give you a nice clean installation and not require you to drill a hole in your air lid to retain the factory IAT sensor.
Old 10-10-2010 | 11:54 AM
NitrOmm's Avatar
thanks for taking the time to explain that. Its this kind of help that makes this site a great place
Old 10-10-2010 | 12:41 PM
HavATampa's Avatar
I bought the same pigtail from Fast Toys Performance and still cut it up and soldered it together. If you use all those connectors, it makes for a huge clump next to the MAF, no way to hide it. Much cleaner install without the connectors IMO.
Old 10-10-2010 | 12:47 PM
dgcustomz's Avatar
I have my wiring going under the smooth bellow and wraps around it. looks good imo.
Old 10-10-2010 | 12:54 PM
dgcustomz's Avatar
Here are some pics of the harness before I went to a fast92/92. Click ont he pics and they will enlarge.
Old 10-10-2010 | 08:52 PM
NitrOmm's Avatar
I found a few Delphi 85mm MAF's ( GM part # 25168491), the wire harness adaptor and smooth belows.
After looking at the photos above, I notice that my MAF has aluminum parts in front and back that sandwich the MAF with four bolts. The new truck/vette MAF has only three bolts.
My question: what will I need in order to adapt the MAF to fit between my lid and new MAF as well as attach to the new smooth belows. It seems that you have a cupling between your lid and MAF ( yours goes around the outer diameter of your lid while mine allows the lid mouth to go over the outer aluminum part, with clamps over each side).
Seems that I will loose some distance etc..
Old 10-10-2010 | 09:47 PM
dgcustomz's Avatar
I was running a stock size air lid and an slp85mm maf. So i had to use the coupler to get them to fit. I had to trim the smooth bellow also but it all fit good after that. If you need a lid I would go with a ftp 98mm lid which is 85mm inner diameter so the 85mm maf will go inside the lid. This way you don;t have to cut the smooth bellow.
Old 10-10-2010 | 10:36 PM
01SS99red's Avatar
The Delphi Maf is not that good , if your gonna spend the money on a 85mm your better of doing the right way and a get a GM one from you local dealer there like $140 or so.
Old 10-11-2010 | 05:44 AM
Reaperchild's Avatar
i fabbed up a connector that works great instead of spending time & money on wires (PIGTAIL) .... HINT chop off the plastic cover from your maf connector & as for the IAT find a like wise connector to chop off its covers, thats a bang for da $.
Old 10-11-2010 | 10:29 AM
dgcustomz's Avatar
Slp maf's are delphi's. I f you peel off the slp logo you will see it. I have been running the slp for a while now with no issues.
Old 10-12-2010 | 12:42 PM
legendarysouls's Avatar
so with the delphi do u NEED to tune it and NEED descreen it
Or is it Plug and play with the adapter...
If it is the same as the SLP one y does it say Only use on stock PCM (tune)
Askin a few Q's before i do this as my next mod
thanks
Old 10-12-2010 | 01:26 PM
tittan1500's Avatar
you should re tune and you dont need to de screen but you should if your getting a tune.
the new MAF will screw up your fuel trims with out a tune
Quick Reply: Using 85mm MAF on 99 LS1 car questions
