Opening on a LS6 intake?
Old Jan 29, 2004 | 11:34 PM
JS's Avatar
JS
Default Opening on a LS6 intake?
I'm curious what the opening is on a LS6 intake,75MM,78MM or perhaps 80MM?Anyone ever measure it?
I might try a 80MM TB on my Cartek Ported LS6 to see if its worth anything over my ported stocker TB?I just cant spend that kind of money on a intake (LSX/TB).What are your thoughts?
Has BBK gotten better with there 80MM TB,I know at one time it was real bad and they were having problems sticking too.
$300 or 400 for 5 to 6 RW across the board I'll take but not for 1200 bucks..
Old Jan 30, 2004 | 01:34 AM
frankensteinta's Avatar
I can measure mine tomorrow if you need, I needed to pull off my T/B anyway since somehow my t/b bypass has started to leak????
Old Jan 30, 2004 | 06:03 AM
Viper's Avatar
With the bypass, where is it leaking? I found mine at the connection on the manifold, had to replace the band clamp and only tighten it using a screwdriver ( vs. a socket ).
Don't know the intake size, I can measure mine tomorrow if JS doesn't reply.
Old Jan 30, 2004 | 06:51 AM
Fireball's Avatar
I recall it being 77mm. but I know it IS less than 80mm
Old Jan 30, 2004 | 09:27 AM
JS's Avatar
JS
Thanks guys...
I dont think this is gonna matter since my lid is not a 80MM nor is the MAF?What is the size of the stock maf and lid openings for our cars?If its 78MM them I'm gonna put a 78MM TB on my car just for S&G's and see if it picks up on the dyno.
This LSX is $$$ and IMO not proven...
I'm waiting til I see real dyno results compared via LS6 VS LSX...
J-Rods setup gained hp over the ls6 but lost tq with it and that scares me..
Old Jan 30, 2004 | 09:40 AM
Fireball's Avatar
Originally Posted by JS
Thanks guys...
J-rod lost power IMO due to the flow problems at the TB-plenum interface (using a oval TB and round inlet with no smooth transition).
LG put a 90mm Round TB on the intake and gained 11 RWHP over the TPIS with no loss in torque...thats excellent IMO
Old Jan 30, 2004 | 10:52 AM
JS's Avatar
JS
Thats right Bri I forgot he was using the oval TB...
But do u really think 11RW is worth $1300?
Whats the opening on a MAF/Lid?
I might try the 78MM TB Brian...
Old Jan 30, 2004 | 10:58 AM
Old SStroker's Avatar
Opening is about 75.5 mm, just a tad bigger than the atock 75mm TB. There's almost no material you can remove, so any TB larger than 75 mm needs an adapter to neck it down. That's kind of reverse porting, IMO.
Old Jan 30, 2004 | 11:22 AM
Fireball's Avatar
it would be 20 RWHP for 1300. This is ofcourse assuming you have a LS6 intake. The 11 RWHP was over the TPIS which can show ~8 RWHP over stock LS6
Old Jan 30, 2004 | 12:24 PM
JS's Avatar
JS
Do u really believe its worth 20RW Bri?
Thats worth 1300 for sure......
Guess I'm waiting on a LSX/90MM TB
Old Jan 30, 2004 | 04:45 PM
Fireball's Avatar
I sure hope so...I plunked down my cash for the 90mm setup today
