Kooks released new exhaust for f-body
#521
This exhaust setup looks great. It's damn close to the setup I've always wanted. What's the deal with the BMR DSL? How low does it hang? I'm hearing it scrapes. Is there an alternative to the BMR that gives better ground clearance, or is ground clearance with the BMR driveshaft safety loop not an issue on stock ride height cars? If I could use a UMI or Spohn piece that provides better ground clearance, then why not go with those?
#524
#525
I have had the BMR for 6 years and have never scraped anything. I am stock height, but even if you are lowered I cant see how you would scrape it. If you do you messed up a lot of other stuff along the way.
#526
Good deal, btw what true dual exhaust are you running at this time? Just curious.
#528
Actually when I was asking about the scraping and the dual exhaust the person had at the present I was curious about the person that made this quote because he was saying he had duals that passed under the crossmember sorry for the misinterpretation of what I was wondering thanks.
#529
#530
My duals will be here thursday as well. Hopefully the month wait will be worth it.
#533
Got mine put on last nite. As far as the headers go there are things I like about them more than the arh one, and things I dont, like it hitting my k meber on pass side, and having to pull the starter off to get to the back plug (big hands) But at least I can get the starter out, with the arh headers that wasnt happening.
As far as the cat back. It fits good. I still have to do a little messing around to get things perfect and have no rattles. (i have ocd) It is def loud, I figured it would be, but not as loud as it is. Almost sounds like the borla with the cutout open. It gave it a deep tone, zero rasp, and that built big block chest pounding feeling when standing behind it. I only got to drive it a mile or so, at 65-70 in 6th it is a bit loud, 55 is good. Loud as hell when you step on it.
All in all I am happy with it so far. (be happier when my ARH stuff gets sold) It will take some getting used to, I got the deeper tone without the rasp, I just wish it was a bit tamer at idle and cruise.
#534
Its not crooked it may just seem that way because of the size and location of the two openings togethor because we had to put wood in between the body kit and the exhaust same piece of wood then weld the metal to the hanger so the exhaust would not melt the kit on the back bumber because with the rubbers on the mounting brackets that come off the bumper it pushed the exhaust tipe up against the body kit of the car so we had to create a gap and the same piece of wood was used on both sides.
#536
The way the kit is made if the tip is crroked then it would have to be welded on crooked from the factory. The drivers side tip is welded to the muffler and it has pipe coming off the back of it that has a 90* bend in it. To get one tip crooked the whole system would have to be crooked and I spent quite a bit of time making sure they were even, I hate seeing cars with crooked tips LOL
For those looking to get this exhaust I will say this.... For a true duel 3" system I don't see how you are gonna get much better. The kit went together really good but of course was tight in a few spots. It has a nice deep tone to it, it may be a little loud for some peoples taste though. The lowest spot on the kit I put on Cbruer's car is the crossmember, his car sits a little lower than a stock F body and I still think it will be fine as long as he dont take it four wheeling.
#537
I'm definitely going to order a full Kooks exhaust for next season! Glad to hear it's working with the UMI cross member. Anyone thought of different tips? I am guessing this is the only way Kooks offers them, and I'm okay with the quad tips but would prefer ovals like GMMG with a rolled lip. Anyone else?
#539
Those are the only tips offered in the system as far as I know of for now but people have changed the tips and went to single outs and sold the quads but changing that would be a simple cut off those and have the tips you want to put on there welded onto the end of the exhaust. Just a minor change similar to the change I made with taking off the cats and putting y's for the cutouts and electric cutouts with dumps.
