red bellow?
Old Feb 2, 2004 | 09:41 AM
DreamState23x's Avatar
Default red bellow?
Does anyone know who sells the red smooth bellow.. I saw it on the net a while back but can't find it again.. All I can find now is the slp one.. Thanks.
Old Feb 2, 2004 | 10:14 AM
JF WS6's Avatar
It's probably a red Baker hose.... look in the search there's probably something there.
Old Feb 2, 2004 | 10:54 PM
JBIRD02's Avatar
yeah check HERE and HERE , hope this helps
Old Feb 3, 2004 | 08:39 AM
I did a search and found those. it's not the one I was looking at before so I put this post on here to find the other one.
Old Feb 3, 2004 | 12:32 PM
DARK AGE 53's Avatar
This is what I had on my 99 SS.
Al
Old Feb 3, 2004 | 12:33 PM
demonspeed's Avatar
It's not mine! woo hoo!
You could probably get one from Turbonetics. Just call them up with the dimensions. They have a bunch of different silicon hoses.
Old Feb 3, 2004 | 12:53 PM
DarkAge: where did you get that one from.. Looks nice.
Old Feb 3, 2004 | 07:15 PM
It's the Baker Camaro hose, there's some minor trimming needed. Let me know if you get one and I'll send you more pictures showing you what I mean. Call Darlene at Baker to order one, 1-800-959-7757.
Old Feb 4, 2004 | 07:20 AM
Thanks. I appreciate it. I just ordered one.
Old Feb 4, 2004 | 12:22 PM
The Baker hose is about an inch too long, these pictures show you what I did to get a nice fit.
I removed just under a 1/2" from the 3.75" end.
When you place the stock bellows next to the Baker you can see the angle you'll want to cut.
I marked the area needing trimming with a pencil, the tape shows the area needing trimming ( above the tape ). The best thing to do is remove a little at a time so not to cut it too short.
The finish product should look like this.
Repeating what I've already said before.....When doing this for the first time I would suggest you trim a small amount of hose at a time, that way you won't cut the hose too short ( and you don't want that ). I used an x-acto knife to trim the hose but you can use what ever you're comfortable with, if I can be of any help please let me know.
Old Feb 4, 2004 | 02:23 PM
Thanks, that will be a huge help.. I appreciate you taking the time..
