LS1 Valve Cover Breather/// PCV Valve (NEW DESIGN)
It's not mine! woo hoo!
Correct. There is a plug for the driver side and one simply uses a vacuum cap on the rear passenger. The front passenger goes to the TB as normal. The valley cover hooks to the manifold behind TB. No more external PCV valve whatsoever if running '04 LS6 valley.
Its coming off the passenger side valve cover. I have it routed in with the valley and a catch can at the moment but havent attempted to see if it fixed the problem. I was told I should just run the catch can and block off the driver side valve cover because it was over kill in my situation.
With the LS6 valley cover the crankcase vapors/blow-by will get pulled up and out through the valley cover. So, for a complete evacuation of combustion chamber blow-by on both banks of the engine you need a fresh air inlet on both valve covers. I'd T both fresh air line together before attaching the fresh air line/hose to the throttle body fresh air outlet .. Now for the catch can run a length of 3/8" oil/fuel line hose from the valley cover outlet to the CC inlet, then run a length of hose from the CC outlet to the intake manifold passengerside vacuum port. With the one remaining port on the passenger side valve cover you can cap it, or hook up a breather filter with a check-valve so it'll only open the valve when crank case pressure needs to be released.
a hey maybe you can help me
Bringing up a dead thread here but how many PCV's is everyone running? There's a port on each valve cover and one on the valley if you have a ls6 cover. 1, 2, or all 3?
If I make the 2 valve covers vent to filters with check valves and leave the ls6 valley plummed in I think I'll have less oil consumption
#34
I sent you both PM's, just keep in mind you'll still need some type of breathe filter to attach somewhere along the other end to catch the very slight amount of oil vapors it will release.
trey0153, that seem like a nice piece especially since it has everything you'll need, compact size, and fool-proof 1 second install. The only down side would have to be cost.
#35
#36
I'm not currently not running PCV, but I have a breather style oil cap. The PO blew up the original engine and replaced it with one that had a PCV delete, but he hooked up the original PCV from the car with the breather oil cap. This caused the engine to high idle, and is how I bought it. It has an LS6 valley cover, but i'm not sure which one, i assume the one without PCV. It runs normal now that the PCV is totally capped off in all locations. It also doesn't have a catch can, but i haven't had any issue with oil anywhere or using any? Does this sound at all like everything is correct?
I'm sure I left something out since I'm trying to keep this short.
#37
I have been dealing with oil in the intake and oil consumption for years. Tried many different options with the same results. Both pcv valves, routings, single and dual catch cans etc. even with this new motor and dual catch can setup, after 30 miles it was amazing how much oil was in the super clean freshened up heads that i just put on.
Tearing down my original motor with 7k miles on these heads, the amount of deposits on the back of the valves was mind blowing. After seeing a Copo in person, i blocked the intake and throttle body ports, and ran both valve covers into a catch can with a breather, exactly like a Copo. With this unmetered air, i did notice the car running a little lean according to my wideband.
Anyways, that check ball breather cap mentioned above, since you cannot t them together, wouldnt it work ok to have that breather on both the driver and passenger valve cover and just cap the intake and throttle body off?
I am tired of dealing with all of this oil in the intake. I am just not happy at all with any pcv setup yet.
#38
