100mm MAF - Does it require a retune
Should I be worried about running this w/o a retune? I previously had an 85mm maf from slp.
thanks
I prefer the new LS3/LS7 card style MAF myself (I have both). Haltech makes a nice housing for it and everything. It works great at idle, since its an OEM piece, the only problem is the IAT is scaled a little differently, so you have to either reuse your old IAT or HPTuners has now built in a place for you to fix the IAT error.
Edit: IIRC the LPE MAF has the same IAT difference as well!
Why doesn't Lingenfelter let their customer know this? The scaling of the MAF is related to the MAF itself. Are you suggesting that Lingenfelter doesn't understand the scaling of their own MAF? Main reason to have to re-scale the MAF after having loaded the Lingenfelter tables would be to correct flaws in the tune that existed in the car before installing the new MAF. If the IAT needs to be re-scaled, then the new scale needs to be provided for by Lingenfelter. Something is f'ck up here. Why would Lingenfelter provide a scaling table for the MAF frequencies that are not correct for the MAF?
Its def not that Lingenfelter does not understand the scaling of their own MAF, its that they will not know how much air your car wants. You cannot expect them to.
Would think the fuel trims would self correct. That's why they are there, no? In regards to air mass, MAP, MAF, IAT & ECT should provide enough information to know what it is. The PCM uses IAC, IAT, MAF, MAP, ECT, spark, 02 sensors & has the ability to correct by using LTFT & STFT for idle & normal driving. Further, the PCM uses MAF, MAP, ECT, spark for WOT, of which has PE as a back up. Maybe the reason I don't see issues like you're describing is 'cuz I run OL/MAF.
Only reason I can see for needing a new tune is if the previous MAF had been a restriction which isn't the case during idle or normal driving. Could be the case @ WOT, but, depends. Even if it were a restriction @ WOT, wouldn't be enough to cause a dangerously lean condition.
Even clocking the MAF (rotating it) can affect the readings, which thereby would technically necessitate a tune!
MAFs are almost stupid simple to tune once you done it a time or two, or watched someone else.
And you can't do that with preset value provided to you. A proper MAF scaling is specific to every car/combination.If your MAF is jostling around while you are driving, you have much bigger problems than the tune.... If you are serious with your second comment then I have lost hope for the power of the human mind.
The PCM is just not that smart.
OK, I was wrong. Didn't realize that most consider a re-scale a tune. Yes, I've seen a stock PCM try & tune itself. My statements were made considering that the Lingenfelter scaling was close enough for the PCM to be able to handle. In this threas, the people who have experienced the major differences between their scaling & what the PCM can handle have stated that the PAM cannot, including you. It's just surprising to me. I know how much a head, cam, intake, TB mod changes everything about the tune & requires a full tune. I'm still pretty much shocked, 'cuz @ WOT we're talking 375 g/s & 4000 RPM & above would most likely have a very conservative frequency setting in the MAF scaling from the manufacturer. Understood... we have to rescale even w/ the manufacturers table.
The MAF works differently so it has to be changed. As was said. Both in the HZ of the MAF itself and the IAT settings. Both of those are huge as to how a car runs.
OK, thanks for clearing that up.
