Whats the TRUTH about MAC headers?......
The reason I'm worried about LT headers is that they can be seen from just looking under thye car if a cop decides to pull me over and check. This isn't possible with MAC's. I have read somewhere that MAC's offer the same gains as LT's in the top end, but LT's had more power in the bottom end. Is this true? Recently, maybe people have been bad mouthing MAC's without any reason to back them up.
The set-up I am probably going to be getting soon is the MAC headers, with a 3" AAP y-pipe with CarSound cats welded in. Is there any problem with this? Thanks.
I have installed probably 15 sets of Macs, and seen them dyno'd back to back vs. just about every Longtube out there. Macs will make the same peak RWHP as any 1 3/4 longtube on the market. LT's will more times than not, make slightly more low-midrange TQ (assuming we're referring to a 346 heads/cam engine)...
Port the primaries, and put a good collector on Macs, and they'll perform within 1 tenth/1 mph of a Longtube headers on a 346 ci heads/cam motor. I've seen it, i've done it, and don't repeat results I read about on the internet... PERIOD..
josh
I do think the supplied Y pipe isn't that good so I had a Flowmaster Y collector welded in to help with flow and minimize the drone at 2400 rpms. I also "ported" or cleaned up the inside welds on the primaries. The HTS coating isn't that good, so I stripped the finish and sprayed on some Eastwood Hi-Temp header paint which has held up suprisingly well and will not flake or rust provided you applied it correctly. Installation is a plus with the headers dropping in from the top if you remove the coil packs and valve covers.
94106 for 2.5"
94109 for 3"
stay away from the mac cats.
High flow cats don't cost *that* much power on stock internal cars, maybe 5rwhp/rwtq, but start messing around with H/C packages and you're leaving a noticeable amount of power on the table using them. Some H/C guys pick up 15-20rwph at peak and similar TQ (and gains across the whole rpm range) removing even high flow cats.
IMO, if you don't have to pass a sniffer (which many states don't have anymore for '96 and up cars, OBD scan only), then ditch the cats and ditch them quick.
PS. I can't imagine the hassle it must be for you cali guys having to put stock exhaust back on all the time for these tests. Can't you guys just slip someone some $$$$$?
I probably would have went with LTs if there was an inexpensive option available at the time (like hooker), but there was not. That said, I haev no intention of changing them now.
Tommy
I see no reason to change the Macs, and I have a ton of ground clearance too.Bruce
