Valve cover baffles removed
Old Dec 23, 2010 | 11:22 PM
6.055chevy's Avatar
Default Valve cover baffles removed
Guy I remove the baffles from my valve covers and install the late model valley with the built in pvc valve. Do I need to do anything other than hook up the right valve cover back to the fresh air intake? Then hook the other end to the vacuum port.
thank for your help
Old Dec 24, 2010 | 10:19 AM
KRAZY K 2000 TA's Avatar
why would you remove the baffles?
Old Dec 24, 2010 | 10:47 AM
6.055chevy's Avatar
Sorry I installed stud mounted Comp Cam Rockers and the baffles were in the way.
The baffles where hitting the adjustment nuts.
thanks darrin
Old Dec 25, 2010 | 11:14 AM
6.055chevy's Avatar
Has no one done this?
Thanks in advance
Old Dec 26, 2010 | 04:58 PM
WKMCD's Avatar
thank for your help
I'd tun a catch can in between to catch any oil that will make it past the VC's.
Old Dec 26, 2010 | 05:18 PM
6.055chevy's Avatar
does the catch can go between the fresh air and the valve cover?
Or does it go between the pvc port and the intake. will the fresh air suck oil from the valve cover with no baffles?
thank you for your help
Old Dec 26, 2010 | 05:42 PM
WKMCD's Avatar
It runs between the VC and the PCV. It really depends on how much blowby you have. Some people run a second one to the intake side. My last engine had so much blow by that I could connect to the intake or it would suck oil. I ended up running a small filter on the oil fill. My 427 has almost no blowby and I run both VC's into the downtube in front of the MAF and it stays bone dry. This is without baffles.
Old Dec 26, 2010 | 05:53 PM
6.055chevy's Avatar
Thank you very much. I will see how it acts.
Old Jun 18, 2022 | 12:06 AM
JamesTheGreat's Avatar
Default Grammer Grammer Grammer!!! And an answer!!!
6.055chevy... Who is Guy? And if it is someone, you should have a comma after his name.... WKMCD... "I'd tun a catch can..."??? What is "I'd tun"?? I think you meant "I'd run." WKMCD... You AGAIN!!! From the middle of another post. What does this mean?"My last engine had so much blow by that I could connect to the intake or it would suck oil". What did you connect to the intake? Why does your motor have so much blow by that you needed a filter on the oil fill? FInally, let me get this straight... On your 427, you have both covers routed to 1 vacuum port. The one that's on the Throttle Body itself? The one that see's very little to no vacuum? If I'm reading this right, than either it's not a boosted application, or if it is, than under boost your motor is burning oil like crazy, or pushing it out through the gaskets or seals. These motors (LS) have enough blow by from the factory that they literally put two vacuums, on them. One on both valve covers. Maybe you're really lucky and don't have any, but well... PHYSICS!!! My guess is, based on your grammer, you're just not smart enough to see all the ways blow by happens... To 6.055chevy.. Here's a real answer. If your valve train setup is causing the rockers or studs to hit the covers, then you need to get "tall" valve covers. However, you shouldn't have the nuts hitting. Something is definitely wrong if that happens. Unless you're using full floating rockers with a stud and tall locking "Allen key" style jam nut setup. If that's what you're running, and the jam nut is hitting, it's because they are "tall" and you really need "tall" valve covers. Removing the baffles will cause the sprayed oil from the pushrod to hit the top of the cover and be sucked up by the positive crankcase ventilation system. If this isn't a boosted application then you can potentially run just a breather on the valve cover, however depending on emissions in your area, this may not be street legal.
FInally, I'm personally a fan of have a small amount of oil inside the intake. By being sucked into the combustion chamber past the valve and it's guide, this oil helps to lubricate the valve train, both intake and exhaust, as well has help the cylinder walls get a hair bit of oil from the top side.
Think of it like a 2cycle engine.. I know it's 4cycle, however that small amount of oil doesn't hurt, and help lubricate. Plus oil has a higher flash point than straight gasoline, so with higher compression, it would technically help protect against spark knock. Finally, with something like E85, which has even less of a petroleum product in it, it definitely helps. That's why I think GM removed PCV valves from 2004 and newer. BTW, Alcohol washes oil away, so crank vent oil is a necessity IMO..
I hope this helps.
Hope that helps.
Old Jun 18, 2022 | 01:06 AM
theunderlord's Avatar
Old Jun 18, 2022 | 09:55 AM
Originally Posted by theunderlord
And who was that masked man???? LOL
Old Jun 18, 2022 | 10:21 AM
MySons68C20's Avatar
Was it a full moon last night?
Old Jun 18, 2022 | 10:52 AM
#LS1TechAfterDark
Old Jun 18, 2022 | 10:59 AM
Sounds like some KingTalon junk…I’m looking into this.
Old Jun 18, 2022 | 11:04 AM
also, I like how the drunk guy who bumped a 12 year old thread to chastise about "Grammer Grammer Grammer!!!"
.... spelled "grammar" wrong.
Old Jun 18, 2022 | 11:09 AM
I hope this helps.
Hope that helps.
I’m just gonna set this right here before it magically disappears…
Old Jun 18, 2022 | 01:34 PM
This bozo signed up July 2020.
When was Kingtalon booted?
Old Jun 18, 2022 | 02:29 PM
September of ‘19…
Old Jun 18, 2022 | 03:30 PM
Darth_V8r's Avatar
Moderator
This had me rolling.
