FAST or a 9 inch
Old Dec 26, 2010 | 08:13 PM
Intercooler2's Avatar
When is the S60 best? It is heavier and eats more power... proven facts.
You got a daily! Get the intake and have it worked. You won't get your best numbers like you can with that 10 bolt until it finally gives. Ride it out!
Old Dec 26, 2010 | 08:19 PM
Mac 2002 SS's Avatar
Go with the 9 inch rear-end all the way.
Old Dec 26, 2010 | 08:56 PM
Carl at CRP's Avatar
The S60 eats more power? Proven Fact? Please provide the proof!
Old Dec 26, 2010 | 09:40 PM
VandykeT/A's Avatar
410s are fine for the highway. My camaro has them and I get 24 mpg. And the car might see the track 3 times a year, maybe. As long as spinning won't junk the 10 bolt immediately I'll prolly go FAST. I do alot of roll racing. Thanks
Old Dec 26, 2010 | 09:41 PM
Hot Rod did the testing. Let me get the article... back in a jiff
Old Dec 26, 2010 | 09:53 PM
GM High Tech rather:
TABLE OF REAR-WHEEL HORSEPOWER/TORQUE CHANGES:
Car Rear Old HP/TQ Rear New HP/TQ % Loss
Jensen Camaro Stock 3.42 412.5/390.0 Strange S60 3.73 397.9/376.0 3.5/3.6
Werner Trans Am Stock 3.42 441.2/432.3 Moser M9 3.70 436.6/428.6 1.0/0.9
http://www.gmhightechperformance.com...nds/index.html
14 RWHP S60
5 RWHP 9"
14 RWHP = 102 FAST
Old Dec 26, 2010 | 10:00 PM
smok'nZ's Avatar
MASS seller approved
the 102mm combo is like 1200+ fuel rails,injectors 9" is like 2500-3500 if you can afford a 9" id do that first
Old Dec 26, 2010 | 10:08 PM
Interesting read! Somewhat subjective but looks as if the 9" used less HP.
Goes against everything it should have though with the S60's higher physical location of the pinion, it should have came out just opposite. None the less the testing looked as if it was done as fair as possible.
Thanks for the link!
Carl
Old Dec 26, 2010 | 11:05 PM
westtexasbuff's Avatar
Get the FAST, and sell your stock LS6 intake and save again for the rear.
Old Dec 26, 2010 | 11:18 PM
Weight of internals, 35 splines, etc... It weighs 20 lbs. more and their numbers on the weights look dead on from what I got. Looks like good solid testing and numbers to me.
Old Dec 27, 2010 | 12:02 AM
Squirts11's Avatar
x2. Getting the intake now will also save you the hassle/money of having to retune for again later.
Old Dec 27, 2010 | 12:07 AM
  #32
Zmg00camaross's Avatar
Save your money and wait until you can do both, otherwise i would go rear first.
Old Dec 27, 2010 | 07:19 AM
  #33
KC&97TA's Avatar
Do you run your car or your mouth?
If you run your mouth get a FAST, if you run your car, you're going to need a better axle!
I put a Moser 9" in my car when it was K&N Filter and Lid, those were the only engine mods... build the suspension/axle/tranny first then the motor... once my motor went in I shot from 12.9's to 11.1x's, now I'm knock'n on the door to the 10's with out a worry in the world, full weight street car !
going home on a tow truck sucks, especially when you know the 10 bolt is a ticking time bomb.
Old Dec 27, 2010 | 07:23 AM
  #34
sway99bird's Avatar
Get the 9in and get it out of the way you can always get a LS6 intake for the time being and P&P your stock throttle body for time being that you build up funds for the F.A.S.T. set up.
Old Dec 27, 2010 | 07:24 AM
  #35
ta-stanger's Avatar
My vote is for a intake and see what happens with the rear! To many guys on hear still driven there 10 with alotta power! I think with a little common sense a 10 might make it, but if ur dumping the clucth at 5k and hitting the track every weekend the end is near for the rear !!
I'm going to put an S-60 in but I'm going to try and make it as long as possible!!
Old Dec 30, 2010 | 08:02 AM
  #36
Duffster's Avatar
I've broke 2 rear ends. . . never broke an intake. . . get the rear.
Old Dec 30, 2010 | 08:16 AM
  #37
1BadAzzWS6's Avatar
Your rear is a timebomb... your intake isn't. Do the rear first!
Old Dec 30, 2010 | 12:56 PM
  #38
JonCR96Z's Avatar
If you're going to go to the drag strip the 9 inch will be 10 times better for your ETs than a FAST (on some good tires, ofcourse).
Old Dec 30, 2010 | 02:25 PM
  #39
FST SS's Avatar
^^^ just like he said, build the suspension first then go for more power.
Old Dec 30, 2010 | 02:40 PM
  #40
manfred717's Avatar
I vote 9in as well, might as well as an ls6 intake is not going to hinder you very much but breaking a ten bolt at the track will
