O2 extentions or Bosch 13111's?!?!?!
Old 01-02-2011, 07:49 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Originally Posted by RevGTO
More info about them than you ever cared to know.
Good bunch of info Rev, thanks for the link. Nope, I didn't read it all, it is a lot.
I have had zero issues using the 13111's and I do believe many others here have experianced the same.
Old 01-02-2011, 08:13 PM
Fabian's Avatar
I've had 13111s on my Z28 for 3-4 years now, never had an issue. My dad has extensions on his WS6 for 3 years with no issues.
Old 01-02-2011, 09:19 PM
PheonixLS1's Avatar
Do you have bungs on your pipes for the rear O2?s You'll get a SES if those are missing regardless of how the fronts are functioning.
The real solution is to tune those DTC's out. Do you know somebody who can tune? You're going to want some tuning to maximize your LT's performance anyhow.
BTW, I have a extra pair of extensions lying around. I'll ship 'em to you for $20 if you want to try 'em. Not a big investment and they just may work. PM me if interested.
I'mputting O2 bungs in on the reducer after my cats for the rear O2's just so I can install them for a "visual" inspection to pass. I live 20 miles away from Tuned by Frost. He is doing my DYNO and will be erasing my rear O2 codes anyways, possibly my EGR and AIR codes also. I don't want to erase my front O2 codes because I don't want my A/F ratio's messed up after my tune. I know that if the front O2's are not functioning it can mess the tale up and make your motor run rich or lean and I don't want to spend 375 on a DYNO just to have them screw it up.
Old 01-02-2011, 09:27 PM
Pontiacerator
RevGTO's Avatar
Steve will get you sorted out, then. The typical codes thrown by the front O2's on LT's (slow response, etc.) don't have much effect, if any, on AFR's. Nevertheless, I agree that it's best to have them in top working order for your tune. After that, you can tune out the typical DTC's and not worry about them anymore. That's what did.
Old 01-02-2011, 10:51 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
13111's
Old 01-02-2011, 11:38 PM
sjsingle1's Avatar
i have the short bosch with ext......a yr old...throwing codes now
Old 01-03-2011, 07:12 AM
vidal77boxing's Avatar
Get the densos. I just ordered mine from rockauto.com for 39 bucks a piece.
Old 01-03-2011, 12:01 PM
Pontiacerator
RevGTO's Avatar
The Corvette rears used with LT applications are $55 ea on that site. Still much better than the $90 or so they were going for several years ago. Jegs is still asking $95 for them.
Old 01-03-2011, 06:11 PM
redbird555's Avatar
Get the densos they are about the same price as bosches and are OEM for every new gm vehicle. If your o2's have 90k on them they are probably already worn out and not switching very fast usually people who have lts and use their old high mileage sensors will crap them out in not to long of time. The bosches work for some people but I have seen the 2 switch side by side and can tell you the densos and ngks do it much faster also for every person who has the bosches it seems there are just as many people who have issues with them. Heres my story I got headers at 102k and used extensions one o2 crapped out in a month, ok i went to the store and got a bosch replacement because i needed the car. That bosch lasted 3 months and took a dump I finally said screw it and ordered the densos they've been great too me for almost a year... Again no issues with extensions however with your sensors being that old they probably could use a new set and so why not just eliminate the need for extensions?
Old 01-03-2011, 06:34 PM
MTBSully's Avatar
13111s
5 months and no issues here.
Old 01-03-2011, 07:00 PM
PheonixLS1's Avatar
Sorry for the noob question but what does DTC stand for
Old 01-03-2011, 07:06 PM
  #32
PheonixLS1's Avatar
Part # please
Old 01-03-2011, 07:07 PM
  #33
redbird555's Avatar
idk what the exact acronym is but it just refers to the trouble codes triggering the ses light
Old 01-03-2011, 07:38 PM
  #34
Pontiacerator
RevGTO's Avatar
Originally Posted by PheonixLS1
Part # please
Somebody posted it on page 1: 234-4617. DTC = diagnostic trouble code.
Old 01-03-2011, 09:07 PM
  #35
PheonixLS1's Avatar
Are the wires on the denso's long enough to not need extentions like the bosch's are, or will I have to use extentions on the denso's?
Old 01-03-2011, 09:20 PM
  #36
Pontiacerator
RevGTO's Avatar
The part number listed above is for the ones that don't need extensions (Corvette rears).
Old 01-04-2011, 06:07 AM
  #37
redbird555's Avatar
^^what he said I listed the part number and said they were long enough on the first page.
Old 01-04-2011, 02:10 PM
  #38
senicalj4579's Avatar
Go with the vette o2s instead of extentions. Theres less chance for wire malfunction. Most of us have small issues with o2s and LTS after instal so do yourself a favor and eliminate potential problems from extra connections.
Old 01-05-2011, 11:26 AM
  #39
King Nothing's Avatar
How long you been running the 13111, ad would you recommend these or just do the extensions? Thanks
when i bought my car i had 55K on it and the o2's had never been changed to my knowledge, at 119K i put LT's on with extensions and those lasted to 172K and they finally took a **** on me (3 years or so after LT install and i never got a code but i wasn't tuned for the LT's anyway) i've been running the 13111's for 3 or 4 months now and put 2500 miles on them so i haven't had any problems, but if i do i'll just take them back to o'riellys . . . good buddy of mine works there so they are warrantied for life
Old 01-05-2011, 11:53 AM
  #40
jdiddyws6's Avatar
I was just about to order new stock 02 sensors and some extenders. I think I will go with some corvette rear 02's after reading this. Thanks for the heads up. These would be for rear 02 out of a 02-04 c5 correct?
Quick Reply: O2 extentions or Bosch 13111's?!?!?!
