Hole in my LT Header, pop ?
I am having it welded closed in the morning. But I am wondering if there may be other damage because I am getting popping backfires coming out of the rear exhaust
(not the hole). This happens between shifts and light down shifts. I am driving it very lightly as I do not want to cause damage before I can get the hole closed.
I am wondering what is causing the popping ... my thoughts are that the hole is drawing in air on downshift and helps ignite unburned fuel in the exhaust. My fear is that it is a larger problem like a valve etc.. I should add that it runs and accelerates smoothly and I have always had a raspy exhaust.
The rivet is from a small plate that holds the serial # or model # of the headers.
As mentioned earlier, this does effect my ceramic coating. I will contact Pacesetter to see if something can be done about replacing it.
