Ebay 92 and 102mm throttle bodies...
Old 02-12-2011, 09:53 PM
  #61
Kory 88Iroc Lt1's Avatar
Nice find. I'll probably order one of these for my ls3 intake.
Anyone have any driveability issues?
Thanks,
Kory
Old 02-12-2011, 10:06 PM
  #62
bayer-z28's Avatar
It's a 4" TB. essentially an on/off switch, but will take some getting used to. Still have yet to hear more reviews before I order mine for the FAST 102.
Old 02-12-2011, 10:26 PM
  #63
Jimmy P's Avatar
How does the spring feel? Stiff or weak?
Old 02-12-2011, 10:33 PM
  #64
hitmanws6's Avatar
Ive felt the ebay 102 TB. Spring is stiff, it feels like a solid piece. And it is not an on/off switch. That was an early error on the DBW 102s. FAST changed the angle of the throttle shaft and added the hump to the bottom so that at low speeds air would only flow over the top of the TB, improving driveability/idle quality
Old 02-13-2011, 08:32 AM
  #65
bayer-z28's Avatar
^ Right.. I've read about that through the FAST reviews on their 102 setup. But I mean, essentially.. It's kinda funny in a way. I'll prolly get the eBay TB then. Others say, "Get a NW and do it right the first time!" But if an eBay 102 is basically the same design as the FAST 102, then I'll save $300 on it! For the same piece.
Old 02-14-2011, 07:41 PM
  #66
r572cobra's Avatar
I bought the 92mm,the hole for the iac motor,was to small,I enlarged the hole no big deal.had to trim the bottom of the body because it hit the water pump,still no big deal.was checking the tsp signal on my scaner,and with the screw all the way out,it showed 20 %,checked my buddies throttle body,it looks like the shaft was machined wrong.now because I modifed it,I can send it back!buyer beware.
Old 02-14-2011, 08:06 PM
  #67
Sommer86's Avatar
I bought the 102 TB (and coupler/bellows), but the motor wont be in my car for at least a month (not more than 2), so i dont have any "drivability" comments about it yet, but it sure feels good and is nice and smooth too.
I got to go into the store to buy it and the guys were pretty cool.
BUT...the first TB they brought out was crap. The butterfly was lightly rubbing on the TB, and i wasn't crazy about that. The 2nd one I got was like butter! The spring feels nice and stiff and it's a double spring like the others.
In the pic above it looks like the 102 is bigger on one side, but i did not have the TB centered, it was just a quick mock-up (it's being ported by Tony Mamo). He also told me the TPS needed to be opened up a bit but i'm not gonna sweat it.
I just can't wait to get it installed. Also, it didn't not come with mounting bolts or washers, but we've got a place here in Burbank that sold me AWESOME allen headed black bolts.
Old 02-14-2011, 09:27 PM
  #68
bayer-z28's Avatar
^ No mounting screws?? Cheap asses.. It's not like the stockers will work.
I can prolly find some, but It may be hard around here. And as far as the TSP, you can turn that on these, right? Last time I messed with one was on my 85 Firebird and you had to "clock" the TPS with a volt meter. And that MAF looks WAY too big, IMO.. But only the tuner will be able to say otherwise. I'm doing an 85 on mine.
And our injectors plug into LS3 rails Ok? No difference is sizes with the o-Rings?
Old 02-14-2011, 09:53 PM
  #69
r572cobra's Avatar
Can't clock the tsp,it has positioning pin.
Old 02-16-2011, 11:31 PM
  #70
99slobird's Avatar
I ordered my fast 102 intake Monday it will be here Friday with the rails and everything and Dave at nitrous outlet is coming through with my 102 plate and damnit if my 102 eBay throttlebody ain't 3 weeks back order cause all you guys out there buying them all up lol. So I guess my car will just sit in the shop for another month ..... Just my luck
Old 02-17-2011, 02:26 AM
  #71
RoidedSS's Avatar
god, it's so hard justifying myself to drop that kind of cash on a fast intake...
Old 02-18-2011, 08:31 PM
  #72
bayer-z28's Avatar
^ Talk to the right people and you can get a deal.
My intake came in today. No TB though. Gotta wait a couple weeks for that. (work slowed down) I'm really nervous about taking some sand paper to this thing to smooth out the rough edges. I don't even like taking it apart. Scared of fukin it up. This isn't a $50 part here.
Old 02-19-2011, 04:16 PM
  #73
Rare96LT1Formula's Avatar
Some nice 102 setups you guys are showing off! What kind of injectors are you guys all using? What about your heads/cam to go with it? I've been looking alot at these FAST setups and waiting to bite the bullet and order it.
Old 02-19-2011, 11:57 PM
  #74
LilJayV10's Avatar
subscribed
Old 02-20-2011, 12:14 AM
  #75
vette0009's Avatar
I'll hold off till they've been in use for awhile
They are made in Taiwan
is what I was told from the seller
I'll probably just buy a NW TB
Old 02-21-2011, 07:52 AM
  #76
nocooler's Avatar
Did you do a TPS relearn on it?
Old 02-21-2011, 10:13 AM
  #77
r572cobra's Avatar
yes,the problem is when you hook up the scaner to it,it shows 23% throttle when it supposed to be 0%.
Old 02-21-2011, 10:21 AM
  #78
Golf&GM's Avatar
When you did the relearn on it did you:
Have Engine off
Pull out the TPS connector
Turn the on ignition
SES light should come on, wait for it
After SES comes on, turn ignition off
Plug back in TPS connector
Then start it and scan it. It should read 0%, that works pretty much all the time for me. Sorry if you've already done all that, just making sure.
Old 02-21-2011, 01:15 PM
  #79
r572cobra's Avatar
i will try it,thanks
Old 02-21-2011, 01:39 PM
  #80
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I still bought my RevXtreme 100mm for a good price, but you always find something a little bit cheaper down the road.
Quick Reply: Ebay 92 and 102mm throttle bodies...
