True Duals - muffler selection?
tax return)I don't want to put bullets on, from what I've heard in clips and in person they are just loud, don't have much of a tone to them
I've got it pretty much narrowed down to either Sweet Thunder Chambered Mufflers or 1 Chamber Flowmasters
How do these compare? I do not care about clearance or cost, as both of those can be fixed. I've got MAC headers and a Hotcam, please keep that in mind. How would one sound vs the other? Should I place bullets in front of either of the two, to get rid of rasp? Or will having True Duals get rid of the rasp? I would like as minimal rasp as humanly possible!
Also, are these the right Flowmasters? The first one on the list (I want design D, by the way)
http://www.jegs.com/cgi-bin/ncommerc...10&prmenbr=361
Where else can I buy those Flowmasters? Jeg's is always more expensive I thought
Thanks
I'm running 3" X-pipe with Flowtech Afterburners. It's a unique sound. Check out the 1st post sticky on this forum for the sound clips.
Thanks
Is that a possibility? Do you just run straight pipes from the mufflers straight back and out? I guess that would be a pretty much all custom exhaust job if I did it like that. Also if I ran them under the axle, would that have any clearance issues for a 12 bolt or 9 inch rear end? I'm going to have to have one or the other, my 10 bolt will not be able to hold out much longer
Jamie33, what kind of sound do they produce? They better sound really good for ~150 bucks a piece
I cant believe the difference in sound/tone with my new setup (Pacesetters w/same setup you have) verses when I had the MACs and my old true dual setup. I wish I had a digital video camera so I could let everyone hear what it sounds like. I can only imagine what it will sound like once I finally put a cam in the car
the best way is to hear them in person, but they just sound very clean to me.
i guess kinda more exotic if that describes it.
i dunno i like em, but they are pricey
I'm going to go with the Sweet Thunders. I would like to run them out the back, how hard would it be to go under the axle? I was thinking of running the MACs into either an X or H pipe, then run straight pipes back, then have the Sweet Thunders (they will be 18" long) welded onto some 2.5" in 4" out chrome pipes. Hope 4" won't be TOO big
But I guess I could always get 3" or 3.5" That's one thing I miss about the exhaust that's on there now, it's just a single pipe dumping behind the bumper, but you can see it and it's not exactly pretty
I'd rather have it shoot out the back anyways, so it won't dump under the car and sort of muffle the sound Would it really matter where the Sweet Thunder is located, right after the X/H pipe or all the way at the back? Would there be much of a performance difference if I went all the way out the back? And last, would straight pipes do fine if I'm going under the axle, or will I need some mandrel bends anyway? I figured I could clamp them together near the axle, so when I get the 12 bolt I can take the exhaust off, then put it back on after the 12 bolt is on, rather than having to cut it and reweld it
THanks
This thread has a lot of information, no less than 3 seprate measured test on the first page, about real case mufflers for true duals.
https://ls1tech.com/forums/showthrea...ler+comparison
