FAST 102 question.
Old Jan 14, 2011 | 09:34 PM
ssdungeon's Avatar
Default FAST 102 question.
will a 90MM throttlebody work on a 102 intake? Also anything else besides the fuel rails that would need to be changed over when moving from a fast 92?
Old Jan 14, 2011 | 10:06 PM
garygnu's Avatar
I have herd using the smaller 90/92 TB on the 102 mm intake helps with streetability.some people say the intake o-ring on the intake is exposed with a smaller TB.what brand of TB do you have?is the flange on a fast TB bigger then some other brand of TB.buy the intake ,and if the TB don't cover the o-ring get a bigger TB.
Old Jan 14, 2011 | 10:17 PM
SOMbitch's Avatar
Not sure about the 90 but positive a 92 will fit. I am sure someone will chime in. You will need a ev6 LS2 injector to run on the LS2 rails or a harness adapter to run the ev1 LS1/6 type injector. FAST sells what you need...
Edit: a quick search shows FAST part #170603-1 to convert a EV1 injector to a EV6 LS2 injector harness.
Old Jan 14, 2011 | 10:37 PM
BlackBADaSS02's Avatar
A FAST 92 throttle body will fit. I've seen that others have said that brands, other than FAST, will not fit the 102.
Old Jan 15, 2011 | 12:22 AM
ssdungeon's Avatar
eVEN for the LS1/LS6 style fast 102/R intake? If I will need 8 of these things thats just too much.
Old Jan 15, 2011 | 06:48 AM
garygnu's Avatar
go to FIC for injectors.
Old Jan 15, 2011 | 07:44 AM
ssdungeon's Avatar
Wow if i have to do all that I think ill keep my 92. I am definately not going to buy more injectors. I dont mind doing another fuel rail but fuel rail AND all these adapters are definately not worth it. WHO buys this thing if you have to do all that for all that money? I have 42lb greentops now. I thought I would just have to switch rails maybe or something simple. Looks like i have to switch rails AND purchase adapters or new injectors. Way too much...lol.
Old Jan 15, 2011 | 09:57 AM
Intercooler2's Avatar
Wow. Does get costly! Guess I need to hug my 92 opened to a 96 with 96mm TB
