Dumped off the y
Old Feb 23, 2011 | 10:22 AM
  #101
j.timbs's Avatar
It pretty much just sees the track and some driving around here and there cruising. I put maybe a 1000 miles on a year
Old Feb 23, 2011 | 10:45 AM
  #102
j.timbs's Avatar
quick sound clip
http://s1181.photobucket.com/albums/...t=IMG_0490.mp4
Old Feb 23, 2011 | 12:40 PM
  #103
99Bluz28's Avatar
Yeah I can tell it's loud, when it's overloading the camera mic at an idle.
BTW, what size cam is that, what idle speed?
If it ever gets to loud for you at cruizing speed just install a Magnaflow #14163 (6" dia.,14" case L.) or a #14162(6" dia., 6" case L.), or a Kooks #QCR400 (5.25" dia.,6" case L.). None of these will restrict any flow, just tone it down a bit for cruizing.
Old Feb 23, 2011 | 12:57 PM
  #104
Asian LSX's Avatar
Originally Posted by j.timbs
Hearing this just put a huge smile on my face. Sounds awesome.
I may have to do this to my car for the simple fact I hate the people I live with in my building.
Old Feb 23, 2011 | 01:53 PM
  #105
99Bluz28's Avatar
Here's my new dumped setup.
I'll try to do a video sometime today, wish me luck!
Here's the idle clip!
http://s523.photobucket.com/albums/w...nt=CAM2001.mp4
Old Feb 23, 2011 | 05:57 PM
  #106
mike135531bubba's Avatar
Originally Posted by The Mighty Texan
Thanks man! How you like the dynomax?
It's LOUD! lol car is slowly turning into a track car so it's alright. For a daily, no way could I tolerate it.
Old Feb 23, 2011 | 10:30 PM
  #107
f-body 4 life's Avatar
99Bluz28. how do you like the bbk long tubes. I just installed mine last weekend and im lovin them. My Moroso Spiral Flow came in today and i also will be dumping off of the y.
Old Feb 23, 2011 | 10:54 PM
  #108
99Bluz28's Avatar
I really like them, fitment, finish, price, and especially considering they gave my car better ground clearance which is great!
BTW, I just got my car running last friday, so I really haven't had them on my car any longer then you.
Old Feb 24, 2011 | 05:50 AM
  #109
White.Lightning's Avatar
I had a dumped setup on my car for a little while. The setup is QTP LT's, Kook's 3" ORY, 12" section of stainless pipe, 3" dynomax bullet dumped before axle. Here are a couple of comments:
-The exhaust was LOUD even at idle. I live on a semi tight street. EVERY time I would pull out, my neighbors car alarm across the street would go off. Sometimes, it would set some alarms off basically idling costing down a small hill on my street.
-There was the typical rasp area in the 2200-3000 rpm range somewhere. It sucked because this car is a 100% street car and when cruising around town with stop signs and what not, you hit this rpm range a lot
-WOT the sound was awesome- like no other
-Weight- it was about 1/3 the weight of the Magnaflow catback that is currently on the car
Here is an idle clip (I don't have any cruising videos):
http://www.youtube.com/watch?v=NbLSvTIni-8
Old Feb 24, 2011 | 10:52 AM
  #110
j.timbs's Avatar
Its a Trex cam with a fast 102 and prc 215cc heads
Old Feb 24, 2011 | 04:20 PM
  #111
Yeah ive only tested mine out once so far. Damn Indiana weather sucks! But install was easy after i got the car high enough off the ground, pita with a lowered camaro and using jacks stands!
Old Feb 26, 2011 | 11:35 PM
  #112
The Mighty Texan's Avatar
Thats a nice setup 99blue, why did you do the tip like that (more bends)?
Old Feb 27, 2011 | 06:40 AM
  #113
99Bluz28's Avatar
I wanted to have the exhaust exit closer to the side of the car, and minimize drone/exhaust build up under the car by pointing the turn-down as straight back as possible, plus the 90*bend is a mandrel bend so it's not causing any flow restriction.
Old Feb 27, 2011 | 10:15 PM
  #114
Ah gotcha that's what I assumed, looking good can't beat stainless
Old Feb 28, 2011 | 05:29 PM
  #115
fucter's Avatar
Originally Posted by SmokedOutZ28
Kooks LT, Speed Inc Y with 3'' to 4'' Flowmaster merge with dynomax 4'' Bullet dumped
http://www.youtube.com/watch?v=_gDXhCl__iE
thats louder than my TSP rumblerX true duals
also, I dont have a cutout anymore, I switched to true duals (and so far i ******* love them)
Old Feb 28, 2011 | 05:30 PM
  #116
fucter's Avatar
IMO, the Camaro's look better with no visible tailpipes at the rear unless you have a CME w/rear bumper kit.
now that I notice it, I agree with you
