*General* FAST LSXr 102 thread
Kinda.. Runs like ****, but it runs. Almost sounded like it was miss-firing. Started leaking coolant out of the back of the heads for some reason. I think it was leaking just sitting there, but when I gave her the ole' reach-around to check the plugs in the back of the heads, they felt dry. No idea why it would all of a sudden just decide to leak. I just tightened them down. the last time I actually TORQUED the steam vents I felt it was WAAAAY too tight and though I was going to strip it out.
Anyway.. here's a video.
I gotta take the intake back off to see what's going on, but at least I'm done "clearancing" **** ..................... for now......I take it, it's normal for this thing to NOT want to idle on its own. Had to hold the throttle at about 1/3 to keep it alive. I can't spray for leaks if it won't idle.
*old youtube video link*
Gimme a bit. Got some home-made pie here..
That YT Video editor is basic, but pretty easy to use. Merged the videos together, included two new ones.
http://www.youtube.com/watch?v=rv9p4vMHMto
And I REALLY gotta stick a catch can on my VC-TB PCV line. I had to pull the intake to reseal one of the head plugs and there is already a thin film of oil in the head runners.
Dammit all! Gonna go to home depot today and pick up one of the air line drier canisters. Last edited by bayer-z28; Apr 6, 2011 at 07:19 AM.
also a little trick most people dont do and can cost some hp...take the intake apart so you just have the bottom of the shell...place that on the heads and throw a few bolts in...now see how much play it has back and forth and notice how the port of the intake can restrict the head runner...line up the runners as close as possible for both sides and scribe the heads in front with a marker or razor blade...now when it is together and you are looking to throw it on the car you will know it is in the most ideal spot
Chris
And yeah, i was quite surprised at how well it lined up to my 243 heads. Was almost a direct port match. I think they make the ports small to fit a variety of sizes of heads.
Wish I had a 3m "ball" type pad and a longer die grinder. I would have smoothed out the inside of my runners as well.
Thanks
Just picked up my 102 for $500! Guy I bought it from has never been on the forums. Had it on craigslist.
USE
05/06 GTO pump does not have the raised circular lump of housing on top of the pump next to the pipe, which inturn gives clearance for the TB cable wheel
I really don't know crap about injectors, but I do have (if I remember correct) 42lb injectors that are in the intake the engine came with.
I have Fast fuel rails on the way. I won't mess with any of this stuff until I have everything here.
Where are you guys picking up your braided fuel line for the intakes? Making them, or know a place to get it ready to go(on the 102)?
http://www.compperformancegroupstore...Category_Code=
