*General* FAST LSXr 102 thread
https://ls1tech.com/forums/generatio...p-mock-up.html
Also, there seems to be two options for wire connections on the TSP MAF. My car uses a 3 wire connection. I think I'll try to un-pin the unused plug for a cleaner look.
This beast is coming together. Still waiting on a catch can and a base tune. Damn car has been in my garage since June, but it shouldn't be long before I fire it up
I found a few different part #'s and want to make sure I don't end up with the vette model.
For those who haven't seen it, this is another really good thread about the FAST 102.
https://ls1tech.com/forums/generatio...cs-please.html
and here is my port job, i only took 1 picture, but the ports all look like this. Should I massage the ports any further? Or should this be good enough?
My 102 with the correct fast rail will be fine on a LS1
IF I have the EWP no grinding needed
The MAP can be relocated or turned up wards to clear firewall
I didnt see much info on the oil pressure switch one person said they had to grind intake?
LS3/LS6 valley cover is needed to clear
Is that about the gist of it?
I didn't have a problem with the oil pressure sending unit. But I've have developed a intake install "routine" with these cars anyway. Haven't broken an oil unit yet. Left hand in front of the intake, Right hand in back of the intake, lay on the driver's side headlight and gently inch the intake back into place holding the brake booster line up and away from the OPSU with your right hand.
And I'm stuck waiting on frickin parts AGAIN.. Arrgh.. Waiting on my trans fluid so I can change it and put the car back down. But the car is a little easier to work on when it's on jack stands.
), but all ya gotta do is ask around. Here is my set-up, and I hope it helps some of you out:
-FAST 102 (Mamo ported soon)
-FAST 60# injectors (LS2 style with LS1 harness adapters) NO spacer kit required
-MAP extension for front install (it's mighty tight behind the intake on a Camaro/T/A)
-Godspeed 102 TB (sensor holes need a little "opening up")
-4" connector/bellows
-Callaway 100mm MAF
-FTP 104 lid (just arrive today)
-AC Delco LS2 Water pump (to avoid grinding the OG water pump)
-FAST LS2/Stock style fuel rails
The list above has made my life easy!
Now... the issues below might serve to help others:
The waterpump - Buy a new one for $190 like I did to avoid the grinding or just grind yours....which is a pain.
Injectors - Now we know there is an injector issue, you need the skinnier ones. The skinny LS injectors car be used, but you'll need the FAST spacer kit. The fuel rail will also sit higher due to the spacers. Remember, the 102 is an LS2 based manifold, so LS2 rails SHOULD be used to avoid any leaks and to get the best fitment.
Inline Nitrous Set-ups - Depending on the nitrous set-up, it may not clear a cowl/stock hood.
Strut Tower Braces - Do not fit with 102's. 6litereater is addressing the issue with a new custom design. As soon as my motor is in, we'll begin test fitting.
Are there any other issues to help others out with?
PS: I'm the guy who posted the pictures.
The LS1 water pump (with the 102 being fitted):
Here is my stock (1 month old) AC Delco LS2 water pump (notice it doesn't have the extra hump?
http://cgi.ebay.com/ebaymotors/04-05...s#ht_917wt_939
Part # on the receipt is: 19195105
http://www.rockauto.com/catalog/catalog.php
Hope that helps.
LS2 water pump info:
http://www.rockauto.com/catalog/moreinfo.php?pk=1299071
