*General* FAST LSXr 102 thread
Old Dec 27, 2011 | 08:26 PM
  #281
CBIII's Avatar
How many people just made their own spacers? what did you wind up using/doing?
Old Dec 29, 2011 | 01:49 PM
  #282
Sommer86's Avatar
Originally Posted by camscam02
what are most of you guys using for a bellow for the 102 to 85 MAF?
Originally Posted by djfury05
you should be able to use a 4" silicone coupler since the inside diameter is very close.. maybe some slight stretching over the intake but mine fit fine over the 92mm NW tb and 85mm GM Maf
Correct, I used a 4" and its really snug but perfect! (BTW, this is with a Calloway 100mm MAF and FAST 102 TB)
Old Jan 7, 2012 | 06:01 PM
  #283
SF 1HOTLS1's Avatar
dam after reading all this i think is should just keep my 92/92 combo and send it to tony and have him port it. how much hp/tq gain would i see by porting out my 92?
Old Jan 7, 2012 | 06:09 PM
  #284
themealonwheels's Avatar
Today I finished a swap from a 96mm typhoon intake with a fast 92 tb to a 102/102 set up. Bayer, thanks for the info on the water pump! I set up the intake and tb with an ls2 water pump and it was flawless
One thing that was briefly mentioned, the coolant crossover line. I'm surprised I hadn't read more on it, because it was absolutely necessary to cut it and install a 1/4" fuel line to get under the bigger intake. Just one more thing to plan for in the install!
Also, Bayer, I installed my map upwards with a sheet metal bracket from my typhoon... Thanks for all your documentation!
Old Jan 8, 2012 | 07:31 AM
  #285
a-low's Avatar
^^^ mealon wheels how yud like your typhoon set-up? Think the swap will be worth/money
the hp gains?
Old Jan 9, 2012 | 06:59 AM
  #286
the hp gains?
I did the swap because I got a killer deal on the FAST 102/102 combo. Otherwise, I would have been content with my Typhoon. There are a few other threads on here where we talk about the cost/benefit of a metal intake. A lot of people say heat sink is a myth, I say the airflow used in those calculations is a lot higher than actual and therefore the heat transfer is a lot worse than calculated. All in all, I got the following benefits:
1. Lost ~17lbs switching from aluminum to nylon
2. Gained expansion capability with port work (both intakes are portable, but who has a porting program for the Typhoon like Mamo's 102 program?)
3. Increased opening from 92mm (tb) to 102mm
4. LS6 PCV conversion at the same time
5. Heat sink is not an argument here
But now I don't have to think about heat sink Like I said, if I hadn't got a killer deal on the combo, I wouldn't have done it.
For the price of $350, you can worry about it by buying my Typhoon!
Old Jan 9, 2012 | 08:47 AM
  #287
bayer-z28's Avatar
With the coolant crossover, I just bent mine out of the way. GENTLY. No kinks and clears fine.
Old Jan 9, 2012 | 09:58 AM
  #288
When I ran into the tube, I came back to this thread to see what was done about it. I did a combination of cutting out the center section and bending the DS of the pipe forward to clear, per your comments. Again, thanks for starting this thread and documenting your work, it helped a lot!
Old Jan 10, 2012 | 07:58 PM
  #289
bayer-z28's Avatar
^ Not a problem. As long as it helps people, we can throw as much of our info as we can find in here.
I noticed a HUGE increase in throttle response with the whole setup. Just pulls so much nicer!
Old Jan 13, 2012 | 06:54 AM
  #290
I just took my 383 for the first drive since the swap from a 96 Typhoon with a 92 FAST tb to a 102/102 combo. First thing, the car wanted to die/idle at 2000rpm everytime I put the clutch in but once it got warmed up, I felt it just wanted to idle high instead of dying at every stop light. I realize this is obviously a bad thing that my car doesn't want to drive, but it certainly made me think that the swap must have been worth something because it doesn't want to live on the Typhoon tune anymore
Cruising was fine, but who buys a FAST to cruise smoothly? I got it to an entrance ramp and rolled into second. Now I'm not on anything fancier than 275 street tires, but the car didn't used to break the wheels loose at 3000rpm in second I let it catch traction so I could really feel the pull, and my butt dyno said the 2nd-3rd pull was significantly smoother at the top end.
O.N. may not be satisfied, but I can definitely say this thing fit much better than my Typhoon and the feel has completely changed on the top end. I'm tapped on finances and everyone in my area wants $450+ for a tune, so I'll likely just get a Frost tune next month. Which unfortunately means no back-to-back data for Typhoon vs FAST but I can't do anything when the tuning shops say they "don't care about the numbers between a Typhoon and FAST..." If I get it dyno'd anytime soon, I'll post back here
Old Jan 24, 2012 | 07:10 AM
  #291
SweetS10V8's Avatar
Cleaned up O.N.'s posts, he found out that it was his heads and not the FAST intake causing his issues. No reason to muddy the watters with bad information.
Originally Posted by O.N.
the thread should started off by beating up the LSX heads....lol and not the fast manifold.
Old Jan 28, 2012 | 08:14 AM
  #292
RsSean's Avatar
Where is the post that someone made the SVO 42 ford injectors fit without using the spacers.
Old Feb 7, 2012 | 06:42 AM
  #293
SweetS10V8's Avatar
The intake wasnt designed to work with the fat injectors, but people have made slight modification to make them fit. Do it at your own risk.
Old Feb 20, 2012 | 02:45 PM
  #294
splitfinger09's Avatar
Would these be considered the "fat style" injector that will NOT work with the 102?
Old Feb 21, 2012 | 08:05 AM
  #295
Undertow74's Avatar
Yep! those would be them
Old Feb 21, 2012 | 09:26 AM
  #296
lol of course. So now my tuner is telling me that he has seen these injectors work first hand with the 102. Anyone know how this is possible?
Old Feb 22, 2012 | 11:29 AM
  #297
RsSean's Avatar
They will FIT, rail are made a little different they will fit.
Old Feb 22, 2012 | 01:26 PM
  #298
Ok cool is there any modification needed to make them fit? Also where can I get some new o-rings for the injectors?
Old Feb 22, 2012 | 02:28 PM
  #299
RsSean's Avatar
I havent got mne back from painter, but o rings you can get anywhere.
Old Mar 9, 2012 | 05:34 AM
  #300
ausls1's Avatar
Got my fast 102/102 kit today and just wondering if it's just mine or do all there manifold kits come without throttle body and manifold seals? Do these need to be purchased separately?
