*General* FAST LSXr 102 thread
Old Sep 13, 2012 | 09:01 AM
  #321
Pharcyde50's Avatar
Wow great thread! I just got my VRD ported Fast 102 in. Also ordered a 06 GTO waterpump and FIC is resizing my stock injectors to 42lb because I'm running the fat Lucas 42lbers that don't work well with the FAST 102. I'll post some pics once I get it put on. I splurged on the Fast Billet rails also this setup looks sick!
Old Oct 10, 2012 | 09:00 AM
  #322
Travose21's Avatar
Did any of u guys plug ya evap purge or have it hooked up
Old Oct 10, 2012 | 09:05 AM
  #323
Undertow74's Avatar
Nope, i Like keeping my Evap, don't feel like sucking fumes all the time while driving my car, IMO its not worth getting rid of that just for looks
Old Oct 10, 2012 | 09:10 AM
  #324
Travose21's Avatar
Mine don't plug up to it. Do u have to modify it to make it work and can I just plug it up and not worry about it or do I really need it
Old Oct 10, 2012 | 09:22 AM
  #325
therabidweasel's Avatar
I made a bracket out of aluminum stock from Lowes. This can be made with a drill, hacksaw and file. It is held down by an intake bolt. To that little diving board of a bracket I bolted the OE bracket using two 4-40 screws. I had to bend the hardline just a little by very carefully heating it with a heat gun. Car is in the shop or I would attach pics.
Old Oct 10, 2012 | 09:26 AM
  #326
Travose21's Avatar
Wow. But will it hurt if I just delete it just cap it off
Old Oct 10, 2012 | 11:47 AM
  #327
Travose21's Avatar
Old Oct 10, 2012 | 11:49 AM
  #328
Undertow74's Avatar
you delete the evap and your gonna smell gas all the time, if you don't mind fumes inside/outside your car then go for it and rip it all out.
Old Oct 11, 2012 | 07:51 AM
  #329
Pharcyde50's Avatar
I deleted all my evaporated from intake to fuel tank. No gas smell. I put a small breather on the evaporated line of the fuel tank. My car sits in the garage and no fumes in their either.
Old Oct 11, 2012 | 01:31 PM
  #330
badazz81z28's Avatar
May I ask what breather you used?
Old Oct 12, 2012 | 08:11 AM
  #331
Pharcyde50's Avatar
I just used a clear fuel filter for a breather I picked it up at Advance Auto Parts. Then tuned the codes out with HP Tuners. I also took out the evap hard line form the tank to the manifold.
Old Jan 6, 2013 | 05:02 PM
  #332
RsSean's Avatar
Originally Posted by RsSean
Where is the post that someone made the SVO 42 ford injectors fit without using the spacers.
Originally Posted by SweetS10V8
The intake wasnt designed to work with the fat injectors, but people have made slight modification to make them fit. Do it at your own risk.
Edited: incorrect info given in an informational thread.
Well since SweetS10V8 knows so much to go in and edits MY post, and knows some much about the 102 intake. The post *** hat edit stated that the 42lb injectors will fit, no modifactions to the intake, with the correct rails the injectors WILL FIT and operate with no extra risks then the taller injectors. Here is the prove that the fat injectors work:
So before you edit a post and have to truth behind a statement because you read some where on the internet that they dont fit, wont work. Go try.
Yes the car has over 7k miles with that injector set up in the fast 102, several track passes, still no leaks.
So to the LS1tech people, try it before you take his word .
Old Jan 7, 2013 | 09:22 PM
  #333
Default Cross Over Tube
FWIW, to all searchers.
I had to cut my LS6 coolant crossover tube and install a hose to fit under the 102 TB opening. Today I removed it and installed an LS3 crossover. Much better fit!!
Old May 7, 2014 | 03:07 PM
  #334
ssdungeon's Avatar
Default Rails
From the dead but what rails did you use? I have a set of nasty performance rails on my FAST 92 now and I have a set of the 102 FAST rails. I havent installed my intake yet.
Also if anyone has modified their intake with a dremel does anyone have a video or pics? The 42s are so easy to tune.
Old May 13, 2015 | 11:15 AM
  #335
ericchavez66's Avatar
What could be my issue here? I did notice the arp head bolt washers do extend past the head and could possibly be the issue. Anything else it could be?
Note: It isnt the waterpump, as I have an ls2 waterpump.
Old May 14, 2015 | 09:55 PM
  #336
LilJayV10's Avatar
Attachment 499060
Attachment 499061
You did replace the factory bolts under the intake with button head bolts?
Old Jan 12, 2016 | 11:51 AM
  #337
onebadbowtie86's Avatar
I ordered a fast 102 to replace my stock ls2 intake. can my stock intakes gaskets be used with the fast? I'm pretty sure the intake runners can, but what about the stock 90 mm throttle body gasket, can that be used on the fast?
Old Sep 29, 2016 | 09:59 PM
  #338
pyro719's Avatar
Just got my fast 102 and noticed there are only 5 bolts holding the intake together but seem to be extra holes around the intake for more bolts to hold the two halves together. SeemS like using the extra holes with more bolts would seal the 2 halves together better no? Also I have 3 roll pins sticking out of the bottom of my intake and not sure why or if they shold even be there?
Old Sep 29, 2016 | 11:22 PM
  #339
Randy WS6's Avatar
The bolt that are holding the intake together on the end are fine , the roll pins are to line the intake runner up to the heads , the long intake bolts that go down the side is what help seal the intake together and to the heads . Make sure you torque them ,so you dont warp the intake or crack it. And make sure you use the supplied button type allen bolts that goes to the valley cover under the intake .
Old Sep 30, 2016 | 10:53 AM
  #340
pyro719's Avatar
Cool thank you for that info. I am going to do a little clean up of the ports and inside of the intake. No porting just cleaning up all the casting flash and rough spots. I noticed the removable runners all have slight gaps where the two halves of the runner inlets/trumpets are welded/glued together. Is this a problem?
