98-02 throttlebodies???
JP
JP
use a piece of brass or aluminum as a drift to
punch the shaft out without mushrooming the
end. Easy, give or take how crusty things are.
My home-ported TB is a truck core with my
original '02 shaft and PCV elbow fitting swapped
in.
Don't use a 00+ TB on a 98/99. Just get a 98/99 TB. The porting wouldn't differ between the years, only the throttle camber is different. If you need to, just swap in a 98/99 round throttle camber into the 00+ ported TB and be done with it. You need the correct throttle shaft for the right year or it's not going to work.
Scott
