Car spins but wont run unless you jump
hey man I know this thread is 6 years old but I was hoping to pick your brain about anything you might remember on this issue. I have an ls1 swapped rx7. It came out of a 2001 firebird. Same issue as yours but with a lot more places to look obviously. I even have a bad tps. Essentially the car will turn over strong but won’t start, however if I through a jump box on it it’ll fire right up. I was messing with it the other day tho and realized that after it starts once with the jump box (practically first hit) if I let it die or kill it it’ll spin over for a solid 3-5 seconds before it starts again. My battery is behind the rear seat and is grounded to the chassis. In your opinion do you think that the ground is also my problem. Ps it didn’t always do this. It always started first hit for months and when I got it back from my brother about 8 months later it now has this problem. Also strangely enough it will pop start too. Final note. It has a btr stage 4 cam and prc ported and polished heads along with an ls6 intake and throttle body.
hey man I know this thread is TWELVE years old but I was hoping to pick your brain about anything you might remember on this issue. I have an ls1 swapped rx7. It came out of a 2001 firebird. Same issue as yours but with a lot more places to look obviously. I even have a bad tps. Essentially the car will turn over strong but won’t start, however if I through a jump box on it it’ll fire right up. I was messing with it the other day tho and realized that after it starts once with the jump box (practically first hit) if I let it die or kill it it’ll spin over for a solid 3-5 seconds before it starts again. My battery is behind the rear seat and is grounded to the chassis. In your opinion do you think that the ground is also my problem. Ps it didn’t always do this. It always started first hit for months and when I got it back from my brother about 8 months later it now has this problem. Also strangely enough it will pop start too. Final note. It has a btr stage 4 cam and prc ported and polished heads along with an ls6 intake and throttle body.
The following users liked this post:
Graham Dwernychuk (06-29-2023)
