Hooker longtubes on LS6 Crate Engine HELP!!!
Old Mar 11, 2011 | 05:17 PM
  #61
redbird555's Avatar
I still think its the headers, if the bung hole was plugged up that def says something about the quality and even with their catbacks have been suffering from quality issues. I say try another set of headers like bbks or pacesetters. If the old exhaust fit fine along with the motor mounts then i dont see any problems with the car itself.
Old Mar 11, 2011 | 05:43 PM
  #62
Black98T/A's Avatar
I have spohn poly mounts with 10kmiles on them anyvway of telling they're installed right? I can take a pic
Old Mar 11, 2011 | 07:18 PM
  #63
Black98T/A's Avatar
So so far I've spent roughly $1000 on 2 sets of headers and a y pipe..my car has been sitting in my garage almost 2 weeks..It has a grinder down k member and I have nothing to show for it
Old Mar 11, 2011 | 07:29 PM
  #64
PheonixLS1's Avatar
I still say try the pacesetters.
Old Mar 11, 2011 | 07:42 PM
  #65
Black98T/A's Avatar
Originally Posted by sjsingle1
i.the motor mounts were not put in backwards? motor mount pedestals not switched?
this is a pic of the passenger motor mount
Old Mar 11, 2011 | 07:44 PM
  #66
Black98T/A's Avatar
why do you think the pacesetters will clear the k member and not the Hookers?
Old Mar 11, 2011 | 09:51 PM
  #67
sjsingle1's Avatar
if i remember correctly.........there is a short pedestal and a longer 1..........the long 1 is the drivers side.............short pass........when i did my mounts i had to pay attention to make sure i did not screw it up
Old Mar 11, 2011 | 09:53 PM
  #68
sjsingle1's Avatar
  #69
sjsingle1's Avatar
Old Mar 11, 2011 | 09:58 PM
  #70
Black98T/A's Avatar
You're saying I should try solid motor mounts instead of the poly ones?
Old Mar 11, 2011 | 10:03 PM
  #71
sjsingle1's Avatar
just makin sure you had the mounts in right.....my TSP 1 7/8 fine fit.......glad i did not get hookers
Old Mar 11, 2011 | 10:06 PM
  #72
Black98T/A's Avatar
How do you tell? A shop put my engine and mounts in.
Old Mar 11, 2011 | 10:11 PM
  #73
sjsingle1's Avatar
kinda tricky.......i had to make sure the stop tabs on the polys hit the stop cut out on the mount.......had it backwards 1 time
Old Mar 12, 2011 | 07:42 AM
  #74
redbird555's Avatar
Its a known fact some headers just dont fit as well as others. Like flowtechs which are also made by hookers seem to have problems hitting thing, and some headers like the bbk's or pacesetters simply use a better design. Every header is designed differently and all it takes is to have the jig out of whack when the headers are being welded up and then they will be completely off. There was another guy on here who had qtps which are $800 headers and they didnt fit for shiiittt. After cutting and grinding the k member he finally decided to order a different brand and what do ya know they fit fine. Try another brand bbk's tsp or pacesetter are all good brand that dont have fitment issues.
Old Mar 12, 2011 | 08:47 AM
  #75
Black98T/A's Avatar
Originally Posted by 00pooterSS
I have Hooker long tubes and poly mounts and have no issues with fitment at all, something is wrong.
I don't know why plenty of people have used Hookers with no problems...but I guess I can try and grind a little more of the k member down before I send both sets back wait another week and try the Pacesetters.
Old Mar 12, 2011 | 08:50 PM
  #76
Black98T/A's Avatar
so I grinded the k again..tried and hit..grinded another spot...tried and hit...grinded another spot...tried and hit
whatever spot I grinded down...it then hit another one as it moved closer...i think the only way the Hookers will fit on my car is if I cut the k member completely in half!!!!!
Old Mar 12, 2011 | 08:53 PM
  #77
Black98T/A's Avatar
his i what my K member looks like now and they still hit!
Old Mar 12, 2011 | 09:18 PM
  #78
sjsingle1's Avatar
i think you need a tubular K now
Old Mar 12, 2011 | 09:22 PM
  #79
Black98T/A's Avatar
what are you saying? That my k is fucked??
I have 2 sets of headers and a yipe sitting in my garage...I've wasted almost 2 weeks and spent hours and hours and $1000 on this **** for what a fucked k member!!!
Old Mar 12, 2011 | 09:35 PM
  #80
sjsingle1's Avatar
dont worry.....that k is a pretty stout piece.....when i did my TSPs the damm thing did not wanna go in the drivers side......i spent days tryin to get it up in there......then the light bulb went off.....i took out the motor mount pedestal and it took 2 sec to get it in there.......i was almost ready to drive to texas speed and chunk those headers at them.......maybe you should try removing the pedestal
