Hooker longtubes on LS6 Crate Engine HELP!!!
Maybe the difference in design will clear that K member.
I'm sending back both sets of Hookers...and praying.
. I installed my edelbrocks with stock mounts and had to use a 9" angle grinder on the drivers side k member for about an hour and a half but I got them to fit. I just pulled them out to get a smog and will be putting mine in again for round 2. Call up UMI and have them send you a tubular k member if you are having that much trouble. I think they are in Florida so you could get one fast probably. I give you credit for your patience though.
Hookers-right on top of the K member unable to install even after hours of grinding
Pacesetters-clear it with space and would have with no modification.
