A LITTLE HELP HERE GUYS!!! plz...
Old Mar 23, 2011 | 10:05 PM
cwdub4's Avatar
Default A LITTLE HELP HERE GUYS!!! plz...
ok so i just blew my O2 sensors!! i have to wait till the first to replace them and wanted to know if its bad to drive with them all messed up? alos was wondering if anyone knows if the cats are covered under a federal warrenty if your car is under a certain milage? my car has 73K and i need to change them out so if anyone knows anything I wud greatly appreciate it! and no i will not delete them!!!
Old Mar 23, 2011 | 10:55 PM
02TtopWS6's Avatar
blew them? what did you do to them?
Old Mar 24, 2011 | 07:27 AM
cwdub4's Avatar
wen i say blew i mean they went out
Old Mar 24, 2011 | 07:45 AM
OUTLAWZ RACING's Avatar
Wich ones? The front or the rears? If the rears went it will throw a cat code. The front ones will make the car run bad it will drink a ton of gas. Use a thermal gun to check if the cat is bad.
The exhaust enternig the cat shoud be hotter then the exit.
I think the rule of thumbs is 100* differance.
Old Mar 24, 2011 | 08:22 AM
RARON455's Avatar
And no there aint gonna be any warranty on any of these parts.
Old Mar 24, 2011 | 10:34 AM
boostedbird38's Avatar
when the O2's go bad the pcm goes into a default mode and just tries to guess a/f ratio. so yea, as mentioned it's gonna use a lot of gas and possibly run like crap.
just replace em both soon.
Old Mar 24, 2011 | 03:35 PM
cwdub4's Avatar
thanks guys for the advice, but just wanted to say that today my service engine light went away and hasn't came back on...i havent changed them out but i will asap!!
Old Mar 25, 2011 | 09:02 AM
once you change them both out, disconnect your battery for about an hour and then re-connect and drive around (normal driving) for about 20 mins so the computer will re-learn everything.
Old Mar 25, 2011 | 09:14 AM
firemech21's Avatar
One thing i suggest doing, try pulling all 4 O2 sensors out of the exhaust and clean them I do it at every oil change. Make sure they are cool and spray inside them with throttlebody cleaner. Then shake the $hit out of them. You will see a ton of carb come out of the probe.
Old Mar 25, 2011 | 09:43 AM
bayer-z28's Avatar
Unless it's an auto, there is no real "re-learn" period with the LS cars. The computer figures stuff out within a couple seconds. But the o2 warm up time is a different subject. Heated O2's. No idea on how fast they get up to temp.
Old Mar 25, 2011 | 09:52 AM
Gotcha....guess I'm just used to OBD I Ford stuff, lol
