**STICKY WORTHY** GMMG Exhaust.. How To Eliminate Rasp * Lots of Vids and Pics*
I have a three muffler powerstick set up. 30 inch in the I and two 24's in the back, basically a gmmg clone. Stepped headers 1 3/4- 1 7/8 ory big cam and other stuff. It's loud but not overbearing. It gets nasty when I'm on the gas. No rasp though. I agree the I pipe muffler is the key. I installed mine correctly though. Curious to hear why you should do it backwards? Classic chambered powersticks have a full 3 inch opening all the way through and the fins are pretty small. Not alot of restriction.
I took his advice, bc RevGTO took the advice from EAD.. There is good advice in this thread.. https://ls1tech.com/forums/generatio...very-busy.html
These pics are complimnetary of 97camarozguy
With the grain:
Against the grain:
Here's the system im talking about...
http://www.lmperformance.com/53969/1.html
I still like the GMMG setup more then this one but this still looks like a nice system though.
Thought I would throw this into the ring for the stock guys with cats still
http://www.streetfire.net/video/my-2...ack_194529.htm
And now with the cutout open
http://www.streetfire.net/video/my-2...pen_194532.htm
But like you said, I like the original GMMG design versus this design
Only 1 i found with a 4th Gen, come across alot of 5th Gen's with StainlessWorks exhaust though.
http://www.youtube.com/watch?v=X887tqXE_j0
Yea, being a full 3" & 3.5" setup was what caught my attention when i 1st looked at it. Still saving up money for the GMMG so who knows, maybe ill change my mind and give that setup a shot.
#32
So your saying that running the exhaust gas into those little caves as oppose to over them is a good idea? It would seem that would cause A TON of turbulence and distortion to the gases as they are trying to make their way thru the pipe because you're turning it all back into the oncoming flow. Not saying this is good or bad but a very interesting theory nonetheless. I could see the idea of helping with the rasp but I wonder JUST how much more it is helping and at what costs as well...
Thanks for sharing this info as too often I find myself skimming thru tons of similar thread when all people need to do is search, or hopefully soon, just read the stickies.
#34
All I can say is I'm going by what RevGTO who was told from EAD performance to install it against the grain.. Or backwards. Then I hear a lot of people that are buying the powerstick, that this specific company is telling them to do the same thing
Have listened to my vids? I can post a before vid of jsut the merge and no powerstick vs merge and powerstick. You can tell how quieter and tamer it got with the powerstick in the i pipe
O/R Y, Flowmaseter Merge and GMMG C/B
Current set up in sig
#35
Pontiacerator
My theory is that rasp is caused by individual exhaust pulses colliding and resonating in the system. The powerstick installed "against the grain" is especially effective at shearing the individual pulses and smoothing them out. It doesn't cost much, if anything, in terms of flow because the powerstick is a larger chamber (3.5") that preserves the a true 3" open flowpath. The pulsating gases enter, are sheared, are smoothed out and the rasp is toned down.
Cats have a similar effect on a different principle: the cat works like a strainer to smooth out and equalize exhaust flow. The use of both cats and powerstick is super-effective at killing rasp on a GMMG w/LT's.
Thanks TORCHD for getting the straight story out on GMMG that we have addressed over and over in so many threads!
#38
I feel it was time to make a thread.. A Flowmaster merge doesn't do anything for rasp. In fact it merges the exhaust gases better, even possibly causing more rasp. The idea here was to educate people that yes you should get a Flowmaster Merge, bc most merges on y pipes are terrible. But they key component was the powerstick installed agains the grain in the i pipe. My vids are proof that I killed about 98% of my rasp with the powerstick.
Thanks for coming in and adding more info!
#40
So here is some input.. When I got my cam installed I was running LTs, 3" O/R H and Flowmaster 1 chambers (the race series), stock injectors, MTI clear lid, ASP UDP, 160 T-stat and stock MAF.. And I dynoed 415/378 on a mustang dyno
Then I switched to the set up in my sig MINUS the powerstick, added 42# injectors, FTP 85mm Lid, 85mm MAF, same ASP UDP and same 160 T-stat. and I dynoed 419/382.. on the same dyno as above. So maybe I picked up a little power with bigger lid/maf combo or the exhaust set up in my sig...
But GMMG was rated as one of the best flowing catback.. The only draw back to it is it starts at 3" then gets reduced down to 2.75"
