Underdrive pulley or SSRA?
Old Mar 27, 2011 | 10:51 AM
chrs1313's Avatar
a good performing ram air is definitely one of the best bangs for the buck...It was my second mod on my car back when i was SI, only to the lid...
A perfect time to do a pulley is when you are going to put a cam in....
Old Mar 27, 2011 | 11:44 AM
TXZ28LS1's Avatar
Originally Posted by zracer323
You will see larger gains at the track with the SSRA. Wont pick up much, if any, on the dyno. However it will not fit if you already have a external tranny cooler in front of the radiator.
Damn so the SSRA wont work? I have a tranny cooler..
Old Mar 27, 2011 | 07:06 PM
Raise's Avatar
If you have plans on a cam in the future, I would wait on the pulley until then. It really is a lot easier then since you have to have the stocker off anyway
Old Mar 27, 2011 | 07:37 PM
Jay-P's Avatar
It will work, you just have to be creative with your cooler placement. Do a search in the auto trans section.
Old Mar 30, 2011 | 02:47 PM
Msilver's Avatar
Originally Posted by ULTIMATEORANGESS
i lost zero driveability. but i only have a crank pulley since i have an auto. in my case i just had my idle raised slightly.
Idle quality is part of driveability, higher idle means a lose in drivablity. I never said it was not streetable, I think he would be perfectly fine doing this mod to his car, but there is a small lose in drivablity.
Old Mar 30, 2011 | 03:01 PM
senicalj4579's Avatar
I got your SSRA and trans cooler right here. Post #132 page 7
https://ls1tech.com/forums/automatic...ll-thread.html
Old Mar 30, 2011 | 05:29 PM
Bocefus's Avatar
ULTIMATEORANGESS, what did you set the idle at?
