Pcv mod
Old Apr 25, 2011 | 08:00 AM
robster's Avatar
Default Pcv mod
Anyone have a link to some pictures of how to do the mod or can anyone post some.
Old Apr 25, 2011 | 08:16 AM
bayer-z28's Avatar
^ PCV Mod? Catch can? Or do you mean the EGR?
Old Apr 25, 2011 | 10:11 AM
robster's Avatar
Pcv catch can mod. I have an 02 camaro with lt's so egr is gone and i need to know how to route the hoses so i dont have any open hoses.
Old Apr 25, 2011 | 10:37 AM
bayer-z28's Avatar
Check in here;
https://ls1tech.com/forums/generatio...outing-ok.html
Old Apr 25, 2011 | 11:09 AM
robster's Avatar
So you are running from the valve cover to the catch can to the lower fitting on the tb?. What about the hose from the rear of the intake
Old Apr 25, 2011 | 06:03 PM
bayer-z28's Avatar
If you are keeping the old PCV system (larger hose) run that to a catch can, and from the can to the lower port in the back/bottom of the TB. The smaller hose coming off the front of the pass VC is another system; run that to a can, then the can to the top of the TB.
There are two systems.
Old Apr 26, 2011 | 06:57 AM
BIG_MIKE2005's Avatar
Really dont "need" 2 cans though, just toss a one way check valve in the fresh air hose from the top TB connection to the front pass. valve cover nipple. Then it will only allow air to be sucked into the valve cover but wont allow the blow back into the TB.
Thats what I'm doin anyway.
Old Apr 26, 2011 | 07:03 AM
bayer-z28's Avatar
^ Could prolly almost use another PCV Valve (checck valve) on that one, come to think of it. I'm gonna have to do a can setup soon. My 102 swap wasn't even running 5 minutes and there already a thin film of oil on the intake ports. Had to take the intake off to fix a head plug leak.
Old Apr 26, 2011 | 07:34 AM
Yea, I got to thinking about the PCV/can routing & how some set-ups are really involved & some are really simple. I like simple & efficient. So I'm capping the rear pass. valve cover nipple, putting a 1 way valve in the fresh air to the front nipple, running a 3/8" line from the rear driver side to can, then in the line from the can to the intake putting a stock replacement check valve(ball style). I"m putting it after in hopes of the can catching the oil vapors & letting the PCV valve live longer & hopefully not get clogged up like in the stock location.
