Oil Cooler and Temp Gauge Install
Old May 19, 2011 | 08:10 AM
01ssreda4's Avatar
I know this doesn't help much...but with that fast of a car, you SHOULD have a trailer. Cool that it can make the drive though.
Old May 19, 2011 | 08:24 AM
Frozen WS6's Avatar
Yeah that is the plan and I will just for going to the track incase I break. I just had to make a statement up here since only 5 guys have ever had a 9 second car that could drive on the street. There aren't even many 10 second street cars up here. My goal is to drive to the track run a 9.50 and drive home. And the 150 shot I've used twice isn't even pushing it yet.
It's just so much fun driving a 9 second street car pissing off the person next to me in traffic trying to talk on there cell phone and they can't hear, setting off car alarms in parking lots. I drive it to work (70 miles round trip) and around to carshows, a lot of places. I probably put close to 2,000 miles on it last summer (which is a lot for really nice cars up here).
Old May 19, 2011 | 09:31 AM
Paul Bell's Avatar
That's MISTER MODERATOR
I'll bet you **** off the cops even more
Old May 19, 2011 | 10:26 PM
Frozen WS6's Avatar
Actually they havn't really bothered me too much because I don't give them any reason to pull me over. No speeding, not doing anything stupid, I already know I'm being watched. The only thing they could actually warn me about would be the noise.
The harley guys love it, it makes there bikes sound quiet. Lol
Old Mar 20, 2016 | 12:03 AM
LSDevo's Avatar
I like what you did here. I would like to do what you did, but relocate the oil filter in the process. I wonder if Mocal makes a thermostat for that application?
Old Mar 20, 2016 | 07:25 PM
Frozen WS6's Avatar
It's possible that someone makes a combo unit like that.
Mocal does not make a filter relocation kit, but you can get a one from Scoggin Dickey, Summit, or Jegs.
Old Mar 20, 2016 | 11:50 PM
LSDevo's Avatar
Good to know.
So when you change your oil, your oil cooler wont be fed oil because of the thermostat. So, doesnt this imply that your oil will be low if/when your oil meets or exceeds the temperature of the thermostat and starts being fed through that additional loop to the oil cooler?
Old Mar 21, 2016 | 07:55 AM
Frozen WS6's Avatar
Correct. There is a bypass to allow it to just loop back without going through the cooler.
When changing the oil it will do the same as putting on an empty filter. When you start it the first time the oil level will be lower and you'll need to add more to bring it up to the correct level on the dipstick.
Old Mar 25, 2016 | 12:00 PM
imma_stocker's Avatar
Haven't been able to confirm which adapter fits with Kooks stepped headers until now, thank you sir. Any updates or changes?
Thermostat is a bit less critical here in Texas lol
Old Mar 25, 2016 | 10:26 PM
Frozen WS6's Avatar
Glad I could help you out. I had to just try stuff to see what fit behind my kooks stepped headers. There wasn't much out there back when I did it.
No changes yet. I had pcm issues and decided to park it until my boy got older. He's 4 now so I'm trying to get back to it and get it back on the street and track.
The plan right now is gut all the wiring that isn't needed and convert it to a Holley standalone and gauge. Which will simplify things because it can control multiple things like my 2 step/ timing retard/ launch control box.
Old Apr 3, 2016 | 12:27 PM
SmokedOutZ28's Avatar
Do you remember how thick the ligenfelter piece was? and what headers are you running?
I am hoping there is enough clearance to use a autometer pressure sending unit.
Old Apr 3, 2016 | 01:08 PM
  #32
Frozen WS6's Avatar
I can't remember. But it wasn't very wide. I have Kooks stepped headers and have enough clearance on them for the auto meter sending unit also. Here are some pics of the gap and sending unit.
Old Apr 3, 2016 | 03:44 PM
  #33
Thanks for the info. I'm going to run a oil pressure gauge the sender is a bit bigger but looking at your picture I might have room to run it up top.
The adapter block I'm looking at is 1'' thick.
Old Apr 3, 2016 | 04:24 PM
  #34
Frozen WS6's Avatar
Here's another pic I found of the assembly on my bench. My auto meter sensor is pretty small so I didn't have much difficulty getting it to fit. Also I have an auto meter oil pressure sensor up in the factory location with a T so I could still have my stock gauge function.
1" sounds about right I know it much thicker then the factory block off was.
Old Apr 3, 2016 | 05:10 PM
  #35
I thought about adding a T in the stock location but I am trying to replace my broken switch with the Fast 102 intake on.
I figure the adapter plate would do for the Autometer gauge.
Old Apr 3, 2016 | 05:18 PM
  #36
Frozen WS6's Avatar
Even with my cut back cowl and a fast 92, it can be a challenge to get back there.
That should work as long as the new sensor isn't too big. It might be possible to add a 45 degree adapter on it to get it pointed where there is a little more room.
Old Apr 3, 2016 | 05:34 PM
  #37
tadams72's Avatar
See if you can run a braided line from the port 1/8" npt if I remember correctly then put the sender on the other end (remote mount if you will).
