Stock GM balancer or aftermarket?
I am planning on converting to the Vette front accessories. So I am wondering if I should go ahead & put a GM balancer on it or go with something from the aftermarket....?
if you have the money for the aftermarket balancer go with that man, they hold up to much higher rpm's, i know the ati fluid dampners work well, and i've heard pretty good things about the professional products one as well
I just run a stock one. I've heard of lots of guys on here discover aftermarket UD pulleys causing a high rpm break up/misfiire. This is after replacing everything else trying to track down the cause. Even the SLP underdrive pulley (which i believe is made by powerbond) is advertised that it will not create a false knock. For a few small hp, I'd rather not deal with the potential headache.
