Alternate to Pacesetter Y pipe....
Old Feb 23, 2004 | 11:01 PM
Simp's Avatar
Default Alternate to Pacesetter Y pipe....
I'm considering going with coated Pacesetter LT's in the near future, but have heard terrible things about their Y pipes. Just wondering if there were any other Ys that would fit perfectly with Pacesetters. Thanks.
Old Feb 23, 2004 | 11:03 PM
foff667's Avatar
LS1TECH Sponsor
do a search this has been covered
Old Feb 24, 2004 | 12:22 AM
Tranzor's Avatar
The problem isn't really with the Pacesetter Y-pipe... the y-pipe fit perfectly. It's more with the collectors on the headers themselves. For some reason, the collectors were designed pointing slightly up into the body of the car. This means that any y-pipe that connects to it will basically be right up against the frame of the car. The only way to get around this would be to have a y-pipe custom made at a local exhaust shop.
If you do go with the Pacesetter y-pipe, just do some heavy prying on the y-pipe once it's on to give yourself some clearance. If it's still not enough, just heat it up with a torch and then do more wrenching with a pry bar to get it down. All you need is about a half an inch.
Old Feb 24, 2004 | 10:34 AM
BadAndy's Avatar
You can get a custom y made for the same amout of cash. I had a ridiculously large amount of clearance on mine and it still banged.
Old Feb 24, 2004 | 11:43 AM
Tranzor's Avatar
Well, I think that all depends on what part of the country you live in... all the shops in this area of the country charge $75-$100 for something ridiculously simple like a muffler install.
And forget custom work... if you want something custom, gotta go to one of the few (like 2 or 3) performance shops that have even seen an F-body let alone worked on one and you'll have to pay quite a bit for them to make anything custom. If you don't drive an import here, you're pretty much on your own when it comes to any type of performance work...
Sometimes I really wish I lived in Texas or the Midwest...
Old Feb 29, 2004 | 02:16 PM
Sigma's Avatar
Actually I was quoted 45 bucks for a custom 3 inch y pipe. Needless to say, I won't be buying any y-pipes online.
Old Feb 29, 2004 | 03:19 PM
02redSS's Avatar
must be good quality for $45
Old Mar 1, 2004 | 12:36 PM
JHarmon's Avatar
Duals! My Y pipe had to be extensively modified to fit. See sig to see how I solved my Y issues.
