Finally ordering my Kooks!!!
-JOSH
They are great headers and you won't regret the purchase. Both of mine were stainless no emissions BTW. Trending Topics
As far as the install you will need to get the car about 30" off the ground. If you dont get it high enough you wont be able to work the drivers side header in. You need to drain your oil and remove the filter because it is in the way. You will need an assortment of swivels and extensions. Make sure that you spray the bolts that hook the cats to the y pipe with some kind of lub or else you will have hell breaking them loose. Thats about all, oh yeah and alot of time
I am wondering the gains that you have seen from going to a 1 3/4 - 1 7/8 Step header. Any dyno number differences?
I have dynotech LT step headers and have heard some people say they are great and some say they are not as good as regular LT's, what is your oponion?
Be careful not to cross thread the header bolts! Too many people end up doing this, and the key is to have a buddy hold the header in position while you start the bolts BY HAND. Thread them in as far as you can before you put a wrench on them (I think I got around 4-5 turns easy by hand). I did not have to remove the oil filter to install the Kook's (but I used a lift).
-JOSH
That out of the way, the good is they (headers) cleared everything very well, no cutting, etc. They also tucked up nicely. The headers are well made, short of the emission junk.
You will need: O2 sims if going without cats, O2 ext for front O2s, new GM header gaskets (don't risk a leak), I got stage 8 header bolts (although you can reuse stockers), Emission gaskets (AIR, EGR) if you're keeping them, anti-seeze for O2s (I didn't use them on header bolts, stockers were easy to remove), O2 removal tools (Autozone loan-a-tool), since you're letting a local shop fab up a X pipe you won't need clamps (no a $1200 header package doesn't include clamps
), a good tool set (with metric sockets regular and deep, long ext, wrenchs, etc.)Tips: Remove oil filter and get the car up high. Pry bar can help. Unbolt the tranny cross member so you can make room. Find a friend to help. Give yourself plenty of time (for unseen problems) and have extra money (for the crap that will break, needs replacing, etc)
